Trouble Codes - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Trouble Codes
Old 05-09-2010, 03:15 PM
Warhippie Warhippie is offline
Warhippie is starting off with a positive reputation.
Trouble Codes
Ok i was wandering if anyone knows what these codes stand for.
P1316
P0640
Old 05-09-2010, 03:39 PM
n578md's Avatar
n578md n578md is offline
n578md is gaining momentum as a positive member of FTE.
Injector Driver Module (IDM) Check Operation:
DTCs
P1316 –Injector circuit/IDM codes detected
P1670 – Engine Feedback signal not detected
Monitor execution
Continuous
Monitor Sequence
None.
Sensors OK
Not applicable
Typical Monitoring Duration
Less than 1 second
Typical Injector Driver Module (IDM) Malfunction Entry Conditions:
P1316 – No Entry Conditions
P1670 – Engine is running (mode=2).
Typical Injector Driver Module (IDM) Malfunction Thresholds:
P1316 – The PCM interrogates the Injector Driver Module (IDM) for a 300 μsec, 400 μsec, or 500 μsec extension on the Engine Feedback line. If any of these extensions exist that indicates that the Injector Driver Module (IDM) has stored codes then the fault is set.
P1670 – When a commanded Injector Driver Module (IDM) response is not received this fault is set.
I couldn't find a P0640, although there is a P0460...
Old 05-09-2010, 11:56 PM
mrswift mrswift is offline
mrswift is starting off with a positive reputation.
f250 7.3 turbo deisel runs bad dtc p1670 po478 po485 po470
my wifes f 250 was runnig great the night befor, and we shut it off to go to sleep and when we took off in the morning it set the check engine lite and started running bad, so i had her shut off the engine and restart it ran ok for a few miles and then bad again. so i changed the crank position sensor , and it ran good for a few miles , it set the cel again. i checked the codes and it had po470 , po478 and p1316 i called auto zone and they told me exaust pres sensor failure and exaust back presure sensor failure. i un hooked the ebp sensor and it started running good again, was this just random? or did i bump the injector harness when i was reaching for the ebp sensor, i returned the hyper tech programming to stok and it wont even go over 15 mph now, it has a new code po603 programing error. my wife turned the key off while i was programing it,
i installed a ball buster turbo on my f 350 and 4 inch pipe and super chips set on max ( 6 speed manual) they tols me to unhook my ebp sensor and leave it off . it always has the ebp code but they said that was norma and to ignor it. any ways thats why i unpluged it on my wifes. any help would be greatly apreciated. i tryed to clear the codes , but now it acts like it has several cylinders missing. could this be the injector harnes problem , ill try the wiggle test tomarrow. dtcs po470 ,po475, po478, po603, p1613 or 1316 im dislexic. HELP !!!!!!
Old 05-10-2010, 01:50 AM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Quote:
P1316
P0640
You can look up the codes here:
Ford OBDII Diagnostic Trouble Codes - Overview .: Articles
Old 07-19-2014, 01:22 PM
ga824deere ga824deere is offline
ga824deere is starting off with a positive reputation.
Smile 7.3 code p1316
After much reading on the forum, trouble shooting my 02 F350 4x4. Right bank dead. Traced all wiring had new valve cover gasket replaced. To no avail truck just left shop for 800.00 stopping oil leaks. Well problem has been found # 7 injector bad shorting out complete bank. Code it was showing p1316 you could reset code it would run for 45 seconds then drop complete bank.... thanks for info.
Code Help! Whitey Ford 1987 - 1996 F150 & Larger F-Series Trucks 9 03-23-2016 03:59 PM
ran codes what do they mean? awillo0406 1999 - 2003 7.3L Power Stroke Diesel 20 05-07-2013 02:58 PM
Just got AE...Here are the codes... MiamiPSD 1999 - 2003 7.3L Power Stroke Diesel 2 02-06-2013 05:08 PM
Codes P1152 & P1151 Yellowwr 1999 to 2016 Super Duty 5 02-04-2011 12:21 AM
Code P1247 madcatter33 Modular V8 (4.6L, 5.4L) 7 04-19-2008 08:07 PM
Tags
1316, 1999, 2004, 470, 73, 99, codes, dtc, f250, ford, p0640, p1316, po, po470, po603, powerstroke, superduty, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
