Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 05-09-2010, 09:29 AM
izzybird's Avatar
izzybird izzybird is offline
Garage is empty, add now
izzybird has a very good reputation on FTE.izzybird has a very good reputation on FTE.izzybird has a very good reputation on FTE.
Centramatics
Any of y'all running Centramatics? I have been eyeballing those things for 10 yrs, just can't keep my MT's in check. Can take all the time in the world getting a good balance on them, and within a couple hundred miles I've chucked weights off into the unknown.
__________________
Izzy
2000 F250 Super Cab LB 4x4 ZF6
  #2 (permalink)
Old 05-09-2010, 10:02 AM
ron's power stroke's Avatar
ron's power stroke ron's power stroke is offline
ron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud of
we run this type on our tractor trailers with very good luck...i want a set for my PSD some day..
Centramatic Wheel Balancers
__________________
Early 99 7.3 F350 auto,TN T-4 mount with a s467 for air,SRP 1.1 for oil,H-11 stud's,"NEW" alliant 315/200 hybrids, all supplied by unlimited diesel..shimmed 910's, DI push rod's, full fuel with a fuel lab 4202,TSD sump...tuned by Gearhead..i cant wait to drop her in the truck...
http://inlinethumb43.webshots.com/50...200x200Q85.jpg
  #3 (permalink)
Old 05-09-2010, 10:52 AM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
I've got them on my truck. The place that makes them is right up the road from me in Alvarado.
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 435,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
  #4 (permalink)
Old 05-09-2010, 11:03 AM
izzybird's Avatar
So Chris, are you giving them the big "thumbs up"? I've avoided them because of initial cost, but they're supposed to last virtually forever. So I guess that was a dumb reason!
__________________
Izzy
  #5 (permalink)
Old 05-09-2010, 11:13 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
1999 Ford F-550
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
http://www.facebook.com/http://facebook.com/Kwikkordead#!/Kwikkordead
My dad used to run with those.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, Titan 520's, CCV, EGR, CAT.
2000 VW Passat 1.8t Tiptronic. ZZOOOOOMMMM!!!
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
You cannot explain or explain away the power of God.
  #6 (permalink)
Old 05-09-2010, 11:20 AM
F350-6's Avatar
I haven't found any problems with them. Talking to the guy at the plant, they showed me little sample bottles of the solution and shot they use inside there. They've got a wall in their office with some that came off big trucks with a card stating how many miles were on them. Someone in Canada had a set with 1 million miles. They were in the process of trading him for some new ones just so they could have them to display.
They also work as a pretty good dust shield. I've had them for about 1 1/2 years and so far I'm happy with them. I've got street tires, but my wife has some BFG AT's. Neither of us has had our tires balanced since we put them on.
__________________
Chris
  #7 (permalink)
Old 05-09-2010, 07:19 PM
Bonanza35 Bonanza35 is offline
Bonanza35 has a good reputation on FTE.Bonanza35 has a good reputation on FTE.
Hello, how do they mount on and how much are they. I would be interested also. I have the dually 4x4 cc 7.3 e99. I always have trouble with tire balance and this sounds the way to go. Also where to order them if you please, Thanks guy, Chet
  #8 (permalink)
Old 05-09-2010, 07:22 PM
F350-6's Avatar
Click on the link in post #2 and you can buy them there. They just slide on. Remove the wheel, slide the wheel balancer onto the wheel studs, re-install the wheel.
__________________
Chris
  #9 (permalink)
Old 05-09-2010, 07:47 PM
Fordbronco69's Avatar
Fordbronco69 Fordbronco69 is offline
Infidel
Fordbronco69 is gaining momentum as a positive member of FTE.Fordbronco69 is gaining momentum as a positive member of FTE.
I have em on my truck...im running 35" BFG KM's and i only notice they are on there cuz of the noise. They dont just balance the tires and wheels but the whole outer part of that axle as much as it can so it makes for a nice smooooth ride.
__________________
To Gain Somthing You Have To Lose Somthing...Usually Your Green $$
Kc's 2000 F250 SD SC 7.3L 4x4 6Spd 4" Lift 35" Mud KM2's, DP Tuner, A/C Underdrive Pulley, HP Luk Clutch, Dual exhaust, Stancor GPR, Kwik filter, EGT-Boost-Water-Oil-Fuel, SS HPX, Boost Anni, POR15ed Frame+Oil Pan....PMS!!!
1974 F250 4x4 C6 35" Mud KM's
  #10 (permalink)
Old 05-10-2010, 12:12 AM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
2000 Ford F-250
My Garage
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
I have them on my motorhome with 22.5 wheels.
I heard that truckers use few golf ***** inside the tire to make the same.
Another way is to buy centramatic powder, that goes inside the tire.
All those things work, but you have to figure out the balance between the price and reliability.
  #11 (permalink)
Old 05-10-2010, 12:43 AM
60RatRod's Avatar
60RatRod 60RatRod is offline
1999 Ford F-250
My Garage
60RatRod has a good reputation on FTE.60RatRod has a good reputation on FTE.60RatRod has a good reputation on FTE.
would love to run em, on my list of future mods.
__________________
DanFordMan
EARLY '99 SD CC SB 4X4
PAA MEMBER #96,RHN MEMBER, John Wood's Trans, 6.0 Trans cooler, '06 Front end, Cowl Induction hood, AFE intake, Pete's Cover, Edge Evo Programer, 4" exhaust, CCV mod w/ Oil Trap, Isspro EV2 guages, L.E.D. & A/C mod, 35" Toyo M/T R's 230,000 miles
  #12 (permalink)
Old 05-10-2010, 12:52 AM
UNTAMND's Avatar
UNTAMND UNTAMND is offline
UNTAMND has a good reputation on FTE.UNTAMND has a good reputation on FTE.UNTAMND has a good reputation on FTE.
I have the sand/beads stuff inside my tires also. It seems to work fine unless your wheel is bent. Which if it's bent you should have a new one anyway.
I didn't know they put it in the tire until I pulled one out of te back of my truck and bounced it on the ground, I heard stuff floatig around in there and when you roll the tire you can hear it.
Works fairly well though. I've had the truck up to "missile" speed and it cruises just great.
__________________
JR Strout..aim UNTAMND..00psd4x4ccsbLariet37sTwinTurbo
http://www.youtube.com/profile?user=untamnd#g/u
90 F150 xlt lariat xcab 4x4 long bed 5.8 auto red interior (stock for now) 57000miles
67 Mustang GTA Fastback 390 UNTAMND.com
Tags
225, centramatics, f250, f450, run, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
