Overdrive OFF light flashing on shifter - Ford Truck Enthusiasts Forums
Old 05-08-2010, 08:44 PM
Flashman's Avatar
Flashman Flashman is offline
Flashman is starting off with a positive reputation.
Hello All,
I own a 94 Ford E-350 ex-u-haul box truck. 7.3 Navistar Diesel engine. I noticed that my overdrive OFF light was flashing on my shifter. I engage and disengage it and it would not stop. The only time it would stop temporarily was when I shut the truck off. Or shift to park. The truck seems to shift hard now and then and the trans was rebuilt around 40k miles ago. Any ideas? Thanks.
Joe Flash man
Old 05-08-2010, 11:25 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Read the codes. The flashing light means something is wrong and a code was stored to tell you where to look. Without the code nobody knows what's wrong.
Old 09-20-2010, 09:03 PM
ridnik ridnik is offline
ridnik is starting off with a positive reputation.
error codes
Where do you go to find out what the error codes actually mean? A friend is going to hook my truck up tomorrow to find out what the error code is but what then?Just bought this truck. Drove her twice and now this!The way it is shifting is painful.
1999 ford f-250 4x4 lariat flashing o/d lite. shifts like ____.
Old 09-21-2010, 07:38 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Glossaries, Decoders, Codes, & Charts .: Articles You should get all the engine and trans codes here.
Old 09-21-2010, 07:55 PM
Flashman's Avatar
Thanks for the info guys.
Joe Flashman
Old 09-22-2010, 07:17 AM
Ok I got the codes and they are- p0755 p1715 what next?My buddy cleared the errors and after 5 minutes of driving the o/d lite is flashing and shifts like crap again!
Old 09-22-2010, 08:37 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
You have an electrical failure in the Shift Solenoid "B" circuit that is keeping the solenoid from operating when commanded to do so by the PCM.
Probable faults, in no particular order:
Faulty PCM
Faulty solenoid
Faulty transmission harness (internal)
Faulty harness from PCM to transmission
Faulty connection at the transmission mating connector.
The workshop manual has step-by-step instructions on how to diagnose and repair.
Old 09-28-2010, 06:18 PM
od lite flashes
Go figure some one suggested I clean the battery terminals (they were dirty) and my check engine lite went out.She shifts like a dream and the od lite is no longer flashing!
Old 09-30-2010, 07:46 AM
Guess I spoke too soon.Not fixed.Drove about ten miles and then it started again.
Old 09-30-2010, 12:44 PM
I wasn't going to burst your bubble, but I knew that didn't fix it. Disconnecting the terminals cleared the codes which makes it run like normal until the PCM detects the problem again.
There are instructions above on exactly what you should do. Either that or take it to a pro to fix it.
Old 10-02-2010, 05:21 PM
mike93 mike93 is offline
mike93 is gaining momentum as a positive member of FTE.
"Faulty connection at the transmission mating connector." Go for this one first. I had a similar problem. Mine became loose and was not seated all the way. Also had crud in the bottom of the socket from our latest flooding episode.
Old 10-03-2010, 07:45 PM
thanx Mike 93 Its not something obvious like that. going to the tranny shop.Ive heard nightmare story's about big bills and still the same problem!thanks again.
Old 10-08-2010, 05:39 PM
Took her to Amco trans. in calgary.They tell me there is a mechanical issue inside the tranny and they will pull it. Inspect it and get an est.Here we go...should get a call this aft.Only drove it twice.
Old 10-08-2010, 05:41 PM
Took her to Amco trans. in Calgary.They tell me there is a mechanical issue inside the tranny and they will pull it. Inspect it and get an est.Here we go...should get a call this aft.Only drove it twice.
Old 10-08-2010, 06:30 PM
So the tranny guy says 4 k to fix. 2nd gear went and took a bunch a stuff with it.I dont know what to say.
Overdrive Light BLINKING (F250 SuperDuty) campbell99 1999 to 2016 Super Duty 73 01-11-2017 06:52 PM
No Speedo, Overdrive flashes, Fuel gauge erratic slimfitz 1999 to 2016 Super Duty 1 05-16-2016 06:25 AM
Transmission question Blue Oval 105 1987 - 1996 F150 & Larger F-Series Trucks 5 02-22-2014 08:54 PM
Overdrive light not on. preparation_h 1999 to 2016 Super Duty 3 07-16-2009 09:18 AM
overdrive flashes "off" risky97psd 1994.5 - 1997 7.3L Power Stroke Diesel 58 09-13-2008 07:37 PM
Tags
1997, automatic, diesel, e350, engage, excursion, expedition, f350, falshing, flashes, flashing, ford, light, overdrive, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
