99 f250 SD rear running lights and driver reverse light not working.. - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 05-08-2010, 02:31 PM
marc13 marc13 is offline
marc13 is starting off with a positive reputation.
I have checked the bulbs and fuses but cant figure out why i have no rear running lights and 1 of my reverse lights wont light up either... theres no power going to the sockets. any help is much appreciated
Old 05-08-2010, 03:30 PM
clintbonnie clintbonnie is offline
clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.clintbonnie has a very good reputation on FTE.
Did you check the 10a fuse under the hood in the #12 position ?..which is the upper right of the two rows of mini fuses. And a Big Welcome to the forum...!!
Old 05-08-2010, 04:36 PM
SpringerPop's Avatar
SpringerPop SpringerPop is offline
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
Do you have license-plate lights? They are on the same circuit as the rear "running" lights.
There is a wiring harness interconnect back in the rear that may be either dirty/corroded, or separating from its mating connector.
Here's the wiring diagram for the back-up lights:
http://www.e-toolbox.com/ads/wiring/va112365.pdf
Pop
Old 05-08-2010, 05:22 PM
trying and testing suggestions
i am heading outside now to recheck the fuse which i beleive to be fine. and to answer the other post my plate lights are also not working. 1 plate light has a broken off bulb in it and hasnt worked for a few years but the other is not working. is the wire harness you wrote about a smaller harness with only about 2 or 3 wires in it( not the larger harness with the brake wires or the traile harness?) by the way thanks for the quick responses! this site has been so much help since ive owned the truck and now that ive posted its gotten even better!
Old 05-08-2010, 06:41 PM
Remember you can check fuses without removing them by using a ohm meter, set on resistance mode..
Old 05-08-2010, 08:28 PM
N V US Lawn Care's Avatar
N V US Lawn Care N V US Lawn Care is offline
N V US Lawn Care is gaining momentum as a positive member of FTE.N V US Lawn Care is gaining momentum as a positive member of FTE.
Quote:
check the harnesses...also to be sure it's not the fuse under the hood as suggested earlier...take a look at the dash lights and the front running lights, they will probably be out as well...mine did it, hell, everybody's has at 1 time or another...when you check the harness, if it looks ok, look around for a burnt wire or a loose trailer connection...something caused that fuse to blow, remember that...and search away...
Old 05-08-2010, 08:29 PM
and BTW marc...welcome to FTE...
No Power to Back of Truck No1Hookman 2017 Super Duty 42 12-24-2016 07:49 AM
reverse lights aux mikeyt4e 1999 to 2016 Super Duty 2 03-07-2015 06:12 PM
1995 F350 "Dually" with Electrical Issue IdrinkPBR Electrical Systems/Wiring 5 08-19-2014 08:22 PM
Trailer Reverse Light Wiring cdrmotorsports 1999 to 2016 Super Duty 12 09-08-2010 05:11 PM
Brake, reverse, dome lights not working ChrisLambert Electrical Systems/Wiring 2 07-09-2004 02:56 PM
Tags
1999, 99, duty, f150, f250, ford, front, fuse, light, lights, rear, reverse, running, super, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
