advancetrac problem on 05 explorer limited - Ford Truck Enthusiasts Forums
Old 05-07-2010, 11:54 PM
resq302 resq302 is offline
resq302 is starting off with a positive reputation.
Can anyone help me. My wifes 05 Explorer Limited with the V-8 had the Check Advancetrac message come on in the instrument cluster. Prior to the message coming on, it beeps that the Advancetrac is off. Ive pressed the advancetrac button on the console and nothing happens. Ive also looked through the factory service manauls and it shows nothing in there about this system unless I am looking in the wrong spot. Id rather try and fix it myself instead of getting raped at going to the dealership. Can anyone point me in the right direction as to what to look for or what to test first?
Thanks,
Brian
Old 05-08-2010, 12:41 AM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
See if any of this helps..
ford advance trac problems - Google Search
Service Advancetrac stuck on. Please help rockbust 2007 - 2014 Expedition & Navigator 3 03-05-2017 01:06 PM
Service AdvanceTrac Rubiconrod 6.7L Power Stroke Diesel 31 09-06-2016 05:39 PM
2004 EB Expy, Check advancetrac/abs/ 4x4 high flash josh1095 1997-2006 Expedition & Navigator 3 08-28-2016 09:47 AM
06 Navigator AdvanceTrac issue BA03 Merc 1997-2006 Expedition & Navigator 12 01-27-2016 10:49 AM
Explorer Advance Trac Problem Help! EchoEv1 Explorer, Sport Trac, Mountaineer & Aviator 2 10-29-2012 06:18 PM
Tags
05, 2005, advancdtrac, advance, advancetrac, advant, advatrac, check, explorer, ford, issues, mountaineer, problem, problems, trac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
