1949 ford pickup restoration - Ford Truck Enthusiasts Forums
Old 05-07-2010, 02:17 PM
John-1967 John-1967 is offline
John-1967 is starting off with a positive reputation.
Hello;
I am considering the restoration of a 1948 - 1950 ford pickup. I would like to retrofit the body onto a modern frame, I was thinking a Ranger frame. What is the best frame, fit-wise to use? Is this a big job? Is a Ranger extended cab too long?
Any help / comments are welcome
Thanks
john the rookie
Old 05-07-2010, 02:39 PM
f100newb's Avatar
f100newb f100newb is offline
f100newb is starting off with a positive reputation.
Quote:
Originally Posted by John-1967 View Post
Hello;
Thanks
john the rookie
Get ready for it cause here it comes....
Nothing against wanting to do this and I know very little about the subject but a quick search will get you a VERY long list of pro, cons and differing opinions on the subject. Long story short you are better off keeping the stock frame and retro fitting the important items onto it. Disc brakes, power steering and the like. Unless you like grueling punishment and are a master fabricator I would suggest NOT doing it. Just my .02
That being said there is a site that has some info on using the S10 frame. It is for a Chevy body though not a ford. Good Luck man!!!
Old 05-07-2010, 02:47 PM
1949 pickup restoration
Thanks for the advice.
jf
Old 05-07-2010, 03:02 PM
Old F1's Avatar
Old F1 Old F1 is offline
Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.
Old 05-07-2010, 03:33 PM
Blue50F-1's Avatar
Blue50F-1 Blue50F-1 is offline
Blue50F-1 is gaining momentum as a positive member of FTE.
Hey John. Welcome to FTE!
Do you have the truck yet? From the way your post reads, I'm guessing not. I thought about doing the same thing before I got my truck. The truth was, there is a lot of measuring, cutting, welding, fabricating, and guess work involved in doing a body swap. It can be done, certainly, and picking the right vehicle (S10, Ranger, Bronco II) can make all the difference in the world. BUT, once I actually had my truck I realized that the frame was in dang good shape, as good or better than the S15 I had as an option. Furthermore, having an early BB truck meant that there's plenty of aftermarket to supply me with relatively cheap parts when I can't get them at the old-time part store. Pretty much anything I could want my truck to do will bolt on to the old frame, keeping the body mounted properly while allowing me to add a newer rear end, newer front subframe/ifs, whatever I want.
My advice: Only pull the trigger on this idea AFTER you get a hold of a truck. If the truck you get has a hacked up, rusted out, and/or beat to crap frame...GO FOR IT, if it's got a good frame, save yourself the time, money, and frustration...there will be plenty of other things to use them on.
Good luck!
James
Old 05-07-2010, 03:54 PM
Julies Cool F1 Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
Hi John,
Welcome to FTE.
Yep, this subject comes up monthly. I'd wait to see what you end up with first, then sit down and come up with a plan.
Old 05-07-2010, 08:25 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Welcome John!
Have you owned a Bonus Built truck before? Driven one? I'm curious why you want to zoom straight to a drastic modification straight-away?
By the way, the words "restoration" and "frame swap" are mutually exclusive.
Old 05-09-2010, 08:48 PM
Post to swap frames or not
thanks for the advise everyone. I plan to leave the existing frame and promise to never ask the question again.
jf
Old 05-09-2010, 08:50 PM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
To put things into context, a restoration by definition is to re-create the original. To resto-mod is modify a vehicle but allow it to "look" original, and then there's the full on custom, where everything is changed to an extent. Just swapping frames and drivetrain would typically fall under the resto-mod category. Hope that helps. Anyhow, a Ranger frame with a 114" (113.9) wheelbase is what you'd want to look for.
Old 05-09-2010, 10:03 PM
Blue50F-1's Avatar
jf
Hey, don't let us overwhelm you. We just like to help out is all. Opinions are all most of us have anyway! (at least that we can share)
Whatever you decide to do, keep us updated. We love to see rides in progress no matter what you're doing with them!
James
Old 06-07-2010, 11:57 PM
bandit16t bandit16t is offline
bandit16t is starting off with a positive reputation.
49 F1
My 49 has stock frame. Frame was dropped 8" under cab to keep leg room. Top chopped 6". Wish it was 8" to 10". I would post a picture but cant figure out how to do it.
Old 09-15-2015, 08:41 AM
cdomo057 cdomo057 is offline
cdomo057 is starting off with a positive reputation.
I just picked up a 1948 ford pickup in real rough shape. flat head 6cly frame is real good . Im new at this and have some limited skills and want to learn. what is a good car to retro fit the 48 i want to change out rear end and front steering and use 48 frame can you advise.
Old 09-15-2015, 05:40 PM
Jafo56's Avatar
Jafo56 Jafo56 is offline
Jafo56 has a good reputation on FTE.Jafo56 has a good reputation on FTE.Jafo56 has a good reputation on FTE.
I have 4 of these trucks and I can honestly say these frames are probably much better quality than the newer stuff there's plenty of bolt on stuff or weld on that make the older stuff better, IFS disc brake upgrades and so on
Old 09-15-2015, 05:41 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
We can advise. However I suggest you start a new thread instead of tacking onto a five year old discussion that doesn't relate to your questions. That way the title of your thread makes sense with the questions you are asking.
Welcome to the forum. I hope I don't sound harsh, just trying to help you get the most from your experience here.
Old 09-16-2015, 08:02 AM
[QUOTE=38 coupe;15646339]We can advise. However I suggest you start a new thread instead of tacking onto a five year old discussion that doesn't relate to your questions. That way the title of your thread makes sense with the questions you are asking.
Welcome to the forum. I hope I don't sound harsh, just trying to help you get the most from your experience here.[/QU
ok thank you just learning this site
1971 Ford RHD Postal Van John Durant 1967 - 1972 F-100 & Larger F-Series Trucks 35 10-25-2016 06:48 PM
Chassis number JTB321 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 06-14-2016 10:00 PM
51 Ford pickup original color Jersey devil 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 03-30-2016 01:54 PM
Flareside Bed Mounting Help johnmel59 1961 - 1966 F-100 & Larger F-Series Trucks 3 05-28-2015 04:19 PM
restoring 1953 paul1953 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 03-23-2015 07:16 PM
Tags
1949, 1950, chassis, dimensions, end, f1, f100, ford, frame, ifs, rear, restoration, truck, trucks, wheelbase
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
