1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Moog upper control arm/balljoint...not an installation ?
Old 05-07-2010, 12:53 PM
Methodical_1's Avatar
Methodical_1
Methodical_1 is offline
Expy owners with air suspension that replaced the upper control arm/balljoints with the greaseable, which Moog unit did you use? If you can provide manufacturer and PN...would be appreciated. I'm thinking the RW drive version would work as it appears to have the provision for the solenoid valve bracket but wanted to tap the knowledge base here. Now I wonder if the ones on the truck now is the correct ones.
Reason why I ask is explained below.
I am having problems finding them for my truck with air suspension. Here's the issue. I replaced both upper control arms and balljoints back in July 2008; non-greaseable ones. They are squeaking now. So I plan to return them under warranty. So I go online to do my homework prior to removing and exchanging them; getting part nos and ensuring no problems with a warranty exchange. I find that all they have are the greaseable control arms/balljoints, which is a good thing, but no longer manufacture the non-greaseable ones. I found the following part Nos.
8726 and 8728 (RWD, no specification for air suspension but the picture looks to have the provision for the solenoid valve bracket)
Control Arm w/Ball Joint by Moog - Part K8728T - Advance Auto Parts
8722 and 8724 (4wd w/out air suspension)
Control Arm w/Ball Joint by Moog - Part K8724T - Advance Auto Parts
Note: only difference I see between the control arms (drivers side) with air suspension and without air suspension is one has a provision to mount the solenoid valve bracket.
I talk to Moog tech line and they stated that they no longer manufacture non-greaseable control arm/balljoints for the Expy and that they do not make the control arm/ball joint for the Expy with Air Suspension.
So here I am between a rock and a hard place. I can't exchange my defected upper control arm/balljoint unit under warranty because they don't manufacture a replacement part.
Hope someone can enlighten me.
Thanks...Al
Old 05-08-2010, 10:15 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
If the part you need to replace was bought from Advance A.P. they will replace it with an equal or better part. I have run into a similar situation in the past. TRW and MOOG are (were) by the same corporation that probably made the OEM parts for Ford.
See if you can get the manager to get the 2WD and the 4WD parts into the store to compare. They are probably the same part but the 4WD parts may be a little more sturdily built. If all else is the same I would opt for the 4WD parts.
Old 05-09-2010, 03:37 AM
Methodical_1
Thanks for the response Moto.
I looked at the 4wd version and it does not have the provision (2 raised metal piece that keeps the mount from moving back and forth) to mount the air valve bracket. I know that I can rig something but may look at another brand for an exact fit.
Can anyone suggest another brand to use?
Thanks
Old 05-13-2010, 05:37 AM
Gevans17's Avatar
Gevans17
Gevans17 is offline
Disa[ppointed with Moog ball joints
I replaced my original ball joints with Moogs because they had zerks, but the Moog's rubber(?) boots were shredded in a little over a year.
Old 05-13-2010, 01:20 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
Thanks
I don't know of any other manufacturer that makes these parts, so it looks like we are all stuck with TRW/MOOG. I personally like their products and have been using them for what seems like forever.
Old 05-14-2010, 06:31 AM
Methodical_1
Here's a set I found at Napa...notice the 2 raise metal pieces on the control arm that is what I need to mount the Air Valve bracket for the air suspension. So there is another maker of these upper control arms with grease fittings. Seems like I may have to give them a try.
Store Locator | NAPA Online
Old 05-14-2010, 10:58 AM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
The arms from NAPA look good, I just looked at the units sold by Advance that are made by Dorman and there are some visible differences but I'm confident either arms will work fine. To me the big difference is the price and if there is a grease fitting on the Dorman arms or not. I believe that the Dormans are U.S. made as are the TRW/MOOG units and probably the NAPAs are too. I have found that many greasable parts are shipped/sold without zerk fittings installed but are in a little bag for the installer to use,or not.
Old 05-14-2010, 04:40 PM
Methodical_1
Hey Moto do you have a link for the Dorman control arm?
Thanks
Old 05-14-2010, 11:05 PM
Moto Mel's Avatar
Moto Mel
Moto Mel is offline
Thanks
I found it on Advance Auto Parts site.
Dorman Suspension Control Arm
Part No.</B> 520-215 ******** type=text/javascript> var newDocument = { write : function(content) { $('div#hasReviews_23120').append(content); } }; POWERREVIEWS.display.snippet(newDocument, {pr_page_id : '23120',pr_read_review : "http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Suspension-Control-Arm-Dorman_20514371-P_2070_R|GRP60005_715755529___#fragment-3",pr_snippet_min_reviews: "1"}); *********>
Warranty: LIMITED LIFETIME REPLACEMENT
Front Left Upper; 4WD; Includes Ball Joint and Bushings; Dorman - OE Solutions
$51.99
I think that for the price difference it's worth looking at.
PS; the extra scrambled text came with the ad info, not me.
Driton
1983 - 2012 Ranger & B-Series
09-04-2014 07:37 AM
twall_SD250
1999 to 2016 Super Duty
15
10-23-2012 07:23 PM
93 mix 'n match
1997 - 2003 F150
07-24-2010 12:13 PM
birchy
19
08-21-2009 08:09 PM
rconkl87
2004 - 2008 F150
03-31-2009 08:58 PM
Quick Reply: Moog upper control arm/balljoint...not an installation ?
