Disc brake conversion kis - Ford Truck Enthusiasts Forums
Old 05-06-2010, 10:02 PM
fiftysixfordf250's Avatar
fiftysixfordf250 fiftysixfordf250 is offline
fiftysixfordf250 is starting off with a positive reputation.
Anyone out there have any thoughts to share on the various disc brake conversion kits out there? I'm checking out one that speedway sells. so far they are the cheapest I have found. I want to save but I want quality too. I suspect a lot of companies probably get these kits from the same place. For clarification, I am talking about the ones that fit on the straight axle. I was going with ifs, but I have to scale back a bit. it's not the money...it's the time.
Old 05-06-2010, 11:28 PM
dongc1's Avatar
dongc1 dongc1 is offline
dongc1 is starting off with a positive reputation.
I used ECI for mine. Fit like a glove. They work great.
Old 05-07-2010, 02:46 AM
Julies Cool F1 Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
There's discussions on file for the many threads that have discussed Disc Brake Conversions. I would try the search function to see if you can dig any up.
Herre are a couple I copied:
http://www.ford-trucks.com/forums/865432-new-drums.html
Ya have to scroll down to get to the disc part.
Old 05-07-2010, 02:52 AM
SVT-F100's Avatar
SVT-F100 SVT-F100 is offline
SVT-F100 is gaining momentum as a positive member of FTE.
I have had my truck for just over a month. I spent most of my time cleaning and derusting. I have a paycheck coming up next week and going to do my brakes.
I searched different sites that have complete packages the past month. I drove up to Vintage Fords (Sacramento Vintage Ford Parts, Inc. • 888-Ford-100) in Rancho Cordova CA a couple weeks ago inquiring about this upgrade. Most places that I have found do complete kits with power and equipment. Vintage fords splits it up. They have the equipment package for 399 (kit includes caliper mounting brackets, bearing spacers, mounting hardware, top quality American made rotors, rebuilt calipers with new pads, caliper mounting bolts, inner and outer bearings, hoses and new seals. Mounts to stock Ford truck spindles.)
Then for 425 you get the power parts. And from what the guy at the store told me these two kits combined are meant to cover you end to end for an upgrade.
825 was the best price I found.
Old 05-07-2010, 06:42 AM
55F250's Avatar
55F250 55F250 is offline
55F250 is starting off with a positive reputation.
Quote:
Going by your name,fiftysixfordf250, are you talking about something for a 8 lug set up?
Old 05-07-2010, 07:01 AM
Quote:
I have an F100 shortbed frame that I am setting up to put my cab on. I am hoping to sell some or all of my F250 stuff once my cab is swapped over.
Old 05-07-2010, 10:36 AM
bill henry bill henry is offline
bill henry is starting off with a positive reputation.
GOT MINE FROM ECI,worked great.
Old 05-07-2010, 11:00 PM
rhopper's Avatar
rhopper rhopper is offline
rhopper has a good reputation on FTE.rhopper has a good reputation on FTE.
My son just purchased a complete front disc kit and boosted dual mc from Classic Performance Products for his 59 Chevy Apache. I was very impressed with the quality of the entire kit. Parts were all good quality and everything fit.
Old 05-07-2010, 11:07 PM
vbarker vbarker is offline
vbarker is gaining momentum as a positive member of FTE.
I got my brakes and rotors from Speedway Motors and Power Booster & MC from Classic Performance. Both are great quality and fit good. A lot cheaper than Sacramento Vintage.
Old 05-07-2010, 11:20 PM
firstrider's Avatar
firstrider firstrider is offline
firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.
ECI on the 1ST-RIDE . So simple even a cave man can do it !!!! CORRECTION !!! A cave man couldn't read .
Old 05-08-2010, 02:48 AM
tardster's Avatar
tardster tardster is offline
tardster is starting off with a positive reputation.
I got mine from Classic Performance Products, to me the hardess part was when I had to relocate the grease nipple thingie or whatever you want to call it for the king pins other than that it took a whooping 30 minutes to do. I have had mine on for a month or so with no probs at all.
Old 05-08-2010, 02:58 AM
Steve_B's Avatar
Steve_B Steve_B is online now
Steve_B is gaining momentum as a positive member of FTE.
I used the speedway kit, It is made by CPP
My only small complaint is that they don't include the flexible lines.
Old 05-08-2010, 03:08 AM
tardster's Avatar
Mine came with everything in it for $649.00 plus shipping, heres a link if you want to check it out... Classic Car and Truck Brake, Steering and Suspension Parts
Old 05-10-2010, 03:54 PM
69supercj 69supercj is offline
69supercj is starting off with a positive reputation.
So with this kit from Classic, what do you do about mounting the booster rod to the brake pedal and do you have to change pedals so you dont have too much or too little leverage?
Old 05-10-2010, 04:04 PM
tardster's Avatar
Quote:
All i had to do was bolt it to the pedal. I didnt have to change anything, just adjust it so there isnt too much/little pedal movement. The directions will have all that info in it though...
front disc brake conversion kit JosephPatrick 1961 - 1966 F-100 & Larger F-Series Trucks 25 02-12-2017 03:21 PM
79 DANA 60 rear disc brake conversion crazed87bronco 1973 - 1979 F-100 & Larger F-Series Trucks 55 04-14-2014 09:27 PM
1979 f-250 FRONT disc brake conversion? bigdan1979f-250 1973 - 1979 F-100 & Larger F-Series Trucks 2 01-07-2013 02:32 PM
Wanting disc brakes marmonlj 1973 - 1979 F-100 & Larger F-Series Trucks 1 08-20-2007 09:14 PM
Rear Disc Brake Conversion Kit for 93 F-250 Benrow77 Brakes, Steering, Suspension, Tires, & Wheels 35 08-23-2004 08:00 PM
Tags
1951, 1952, 44, 96, brake, brakes, conversion, dana, disc, disk, fit, ford, kits, speedway, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
