2000 excursion elec issue
Old 05-06-2010, 06:48 PM
beachrods's Avatar
beachrods
beachrods is offline
rear brake and directional lights working - no rear running lights or licence plate lights -- cannot figure this out- any help willl be appreciated
Old 05-10-2010, 11:03 AM
Sparksone42's Avatar
Sparksone42
Sparksone42 is offline
Sounds like a blown fuse to me! Check the fuse panel located directly below the steering wheel to the left, you will need to look at owner's manual to determine the location of the exact fuse. (Sometimes, it's not right either) If it is blown, replace with a fuse of the same size, don't put a bigger fuse in it's place. If you don't find a blown fuse there, there is another fuse box located in the engine compartment but I think those lighting fuses only dealing the trailer connections.
Keep in mind, a fuse usually blows for a reason to indicate there is some kind of problem such as a short or overload condition. If you install a new fuse and it blows again, you will need to find out what the problem is.
Good Luck.
Old 05-10-2010, 11:36 AM
beachrods's Avatar
beachrods
Smile elec issue
Thanks to all who replied- fuses were the issue- peeled all wire wrap covering and found a broke wire - solder and shrink wrapped --all is good !!!
1983 - 2012 Ranger & B-Series
06-13-2015 04:21 PM
Raptorgabe
6.7L Power Stroke Diesel
06-10-2014 11:00 PM
abyars111
11-12-2012 09:18 AM
Mcroz
15
07-27-2012 02:14 PM
blackford97
09-05-2011 10:28 PM
Quick Reply: 2000 excursion elec issue
