Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2009+ F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2009+ F150 Discuss the 2009, 2010 and new 2011 Ford F150 SPONSORED BY:
  #1 (permalink)
Old 05-06-2010, 04:34 PM
davidtxs davidtxs is offline
Garage is empty, add now
davidtxs is starting off with a positive reputation.
reset oil change light
Anyone know the sequence to turn off the light lol
thanks in advance
  #2 (permalink)
Old 05-06-2010, 04:40 PM
shotgunz's Avatar
shotgunz shotgunz is offline
2009 Ford F-150
shotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to allshotgunz is a name known to all
Smile
Preferred method (to avoid embarassment)
1. Open glove compartment
2. Find strange sized paperback provided with vehicle
3. Confirm it has Ford F150 Owner's Manual written on the front
4. Skim book for relevant topic
5. Follow instructions
Alternate method (to encourage harassment)
Depending on your truck (thanks for all the information by the way), it's on page 91 or 103.
Oops, too late, you have already selected the alternate method...
  #3 (permalink)
Old 05-06-2010, 06:14 PM
sigh lol ok well deserved but cant find the dam thing lol
  #4 (permalink)
Old 05-06-2010, 06:34 PM
shotgunz's Avatar
2009 Ford F-150
STANDARD MESSAGE CENTER (IF EQUIPPED)
With the ignition in the on position, the message center, located on your
instrument cluster, displays important vehicle information through a
constant monitor of vehicle systems. You may select display features
on the message center for a display of status preceded by a brief
indicator chime. The system will also notify you of potential vehicle
problems with a display of system warnings followed by a long indicator
chime.
Selectable features
Press and release the SELECT/RESET stem, located in the speedometer,
to scroll and reset the following functions. Select or reset the function by
pressing and holding the SELECT/RESET stem for more than two
seconds.
Setup Menu
Press and hold the SELECT/RESET stem to get into the SETUP menu
sequence from the INFO menu for the following items:
• Oil Life
• Units (English/Metric)
• Rear Park Aid (if equipped)
• Autolamp (if equipped)
• Autolock (if equipped)
• Autounlock (if equipped)
• Easy Entry (if equipped)
• Trailer Sway (if equipped)
• Language
• Reset to English–if in another language (see Note below)
Note: When returning to the
SETUP menu and a non-English
language has been selected, HOLD
RESET FOR ENGLISH will be
displayed to change back to English.
stem to change back to English.
Oil Life XXX% HOLD RESET = NEW
An oil change is required whenever indicated by the message center.
USE ONLY RECOMMENDED ENGINE OILS.
To reset the oil monitoring system to 100% after each oil change
[approximately 7,500 miles (12,000 km) or six months] perform the
following:
1. Press and release the
SELECT/RESET stem to display OIL
LIFE = XXX% HOLD RESET =
NEW.
2. Press and hold the
SELECT/RESET stem for two
seconds and release. Oil life is set to
100% and “OIL LIFE SET TO 100%”
is displayed.
3. While “OIL LIFE SET TO 100%”
is displayed, if a lower oil life start value is desired, press and release the
RESET control to reduce the start value. Each press of the
SELECT/RESET stem reduces the value by 10 percent.
Note: Oil life start value of 100% equals 7,500 miles (12,000 km) or six
months. For example, setting oil life start value to 60% sets the oil life
start value to 4,500 miles (7,200 km) and 108 days.
OPTIONAL MESSAGE CENTER (IF EQUIPPED)
chime.
Selectable features
Reset
Press this control to select and reset
functions shown in the INFO menu
and SETUP menu.
Setup menu
Press this control for the following
displays:
• Reset For System Check
• Oil Life
• Running Boards (if equipped)
• Autolamp
• Autolock
• Autounlock
• Language
• Reset to English (if in another language)
An oil change is required whenever indicated by the message center and
according to the recommended maintenance schedule. USE ONLY
(approximately 7,500 miles [12,000 km] or six months) perform the
following:
1. Press and release the SETUP
control to display “OIL LIFE XXX%
HOLD RESET = NEW”.
2. Press and hold the RESET
control for two seconds and release.
Oil life is set to 100% and “OIL LIFE
SET TO 100%” is displayed.
Note: To change oil life 100% miles value from 7,500 miles (12,000 km)
or six months to another value, proceed to Step 3.
3. Once “OIL LIFE SET TO XXX%” is displayed, release and press the
RESET control switch to change the Oil Life Start Value. Each release
and press will reduce the value by 10%.
  #5 (permalink)
Old 05-06-2010, 08:06 PM
Greg B Greg B is offline
Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.
That looks way harder than just looking at the oil change reminder sticker in the corner of the windshield and replacing when you do an oil change. And it doesn't even tell you what kind of oil you're using. LOL
  #6 (permalink)
Old 08-23-2011, 07:24 PM
jimw411's Avatar
jimw411 jimw411 is offline
2002 Ford Ranger
My Garage
jimw411 is starting off with a positive reputation.
Thanks for the info. I'm in my work van and the mechanics never reset the light and for some reason they take the owners manuals out of the vans when they first get them in.
__________________
2002 Ranger XLT Supercab 2wd 3.0 5spd manual.
  #7 (permalink)
Old 08-24-2011, 06:03 PM
D8chumley's Avatar
D8chumley D8chumley is offline
Resident smarta$$
2010 Ford F-150
D8chumley is a splendid one to beholdD8chumley is a splendid one to beholdD8chumley is a splendid one to beholdD8chumley is a splendid one to beholdD8chumley is a splendid one to beholdD8chumley is a splendid one to beholdD8chumley is a splendid one to behold
tim.burke.167
Oh Mr Charlie I would have been surprised if you didn't respond to this one!
__________________
~ Tim ~
If you can't stand behind our Military, feel free to stand in front of them!
'10 F150 XLT 4X4 CC shortbed 5.4 *5 Star tuned* No Bailout Edition
07 Road King Classic
GO FLYERS! Go Phillies!
  #8 (permalink)
Old 08-26-2011, 05:04 PM
Papi4baby's Avatar
Papi4baby Papi4baby is offline
Papi4baby is starting off with a positive reputation.
Quote:
It's actually pretty easy once you do it.
It looks complex on paper, but it's not.
Tags
150, 2005, 2007, 2009, 2010, change, expedition, f150, f250, ford, light, oil, reset, truck, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Fordฎ is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
