Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-31-2003, 04:26 PM
Gary78 is starting off with a positive reputation.
Glow Plug repair
1996 F-250 power stroke 7.3 diesel
I would like to know if you can test the glow plug continutity through the valve cover gasket.
What is the color code of the glow plug wires and the injector wires?
Gary78
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-02-2003, 03:44 PM
Idaho rockhauler is starting off with a positive reputation.
Smile Glow Plug repair
To test the continutity of the glowplugs carefuly remove the conectors from the valve covers (DONT BREAK OFF CLIPS)They lossen up and get hot. Use A continutity tester on the two outside pins at each connector. I hope this helps.PS if you do break off clips replace the connector, Iv'e replaced two valve cover gaskets and two inside wiring harnesses ABOUT $120 when A $30 conector kit and 20 minutes would have kept them from burning up.
Mike:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
