1996 F150 hard start when warm. P0171 and P0174 - Ford Truck Enthusiasts Forums
Old 05-06-2010, 03:57 PM
Iceman_AKA_Ford guy's Avatar
Iceman_AKA_Ford guy Iceman_AKA_Ford guy is offline
Iceman_AKA_Ford guy is starting off with a positive reputation.
Hey guys my dad has a 96 F150 XL with a 300 6cyl. has lean codes PO171 (lean bank one) and P0174 (lean bank two). When cold, it cranks just fine and runs just fine but when its be ran for a while it hard as hell to start...it staggers and knocks real hard. Dad has to press the gas pedal to get it to straighten up after a few seconds. We've replaced the intake gasket, MAF sensor and EGR valve. There are no vacuum leaks and smoke test didnt show anything. PLEASE HELP!!!!!
Last edited by Iceman_AKA_Ford guy; 05-06-2010 at 03:58 PM. Reason: added more info.
Old 05-06-2010, 05:12 PM
khadma's Avatar
khadma khadma is offline
Carpenter Local 745
khadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud ofkhadma has much to be proud of
First of all did you disconnect the neg. battery cable when replacing/cleaning any of the electrical/sensors/parts? This step is a MUST.
If you did not do the above step, try it, wait 5 minutes, reconnect and take the truck for a drive to reset the computer. Let us know
Did you repalce the O2 sensors?
How did you get codes? Any pending codes?
I wonder if the DPFE is not sending the correct signal to the computer.
Miles on the odometer?
Old 05-06-2010, 05:36 PM
Yes we did disconnect the battery before doing ANY work. Still getting lean codes. We recently replaced the EGR valve but not the sensor near it. We plan on replacing the O2 sensor in front of the cat. tomorrow. miles are 165000
Old 05-31-2010, 05:54 AM
turtlesdove3 turtlesdove3 is offline
turtlesdove3 is starting off with a positive reputation.
Do let us know after replacing it. We'll try to figure out a way with what we know and with some research on the problem.
Old 05-31-2010, 09:20 AM
UrbanXX's Avatar
UrbanXX UrbanXX is offline
UrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputationUrbanXX has a superb reputation
You may very well have a Mass Air Flow sensor problem. This could be the air filter, an air leak in the air filter housing, or a dirty mass air flow sensor.
Old 05-31-2010, 08:33 PM
done replaced the MAF sensor. cleaned it with carb cleaner and now only got P0171. Changed the o2 sensor and still the same problem. any other ideas?
Old 05-31-2010, 08:58 PM
tmm313psu tmm313psu is offline
tmm313psu is starting off with a positive reputation.
have you checked your fuel pressure? what do you come up with?
Old 06-01-2010, 08:09 AM
I dont remember the number but we replaced the fuel pressure regulator, bank 1 o2 sensor, maf sensor, egr valve, and fuel filter. no vacuum leaks anywheres and smoke test showed no breaks.
Old 06-02-2010, 10:11 PM
what prompted you to change the pressure regulator? did you have low pressure? did it fix the pressure issue?
Old 06-03-2010, 08:47 AM
we got told it had low pressure so thats why we changed. it. still got the same problem tho. i wonder if it could be the spark plugs?
Old 06-03-2010, 09:25 PM
did you check the pressure after replacing the regulator? often times on these vehicles a hard start warm is a lack of fuel pressure......the pump could be going bad....
have you pulled a plug or two? it never hurts to know the condition of the plugs....
Old 06-04-2010, 08:14 AM
im not sure if it did or not. i wasnt with him when he got it replaced. We are going to change the plugs this weekend.
Old 06-20-2010, 02:13 PM
Irv Nichols Irv Nichols is offline
Irv Nichols is starting off with a positive reputation.
I have the same pickup with the same problem but my truck has dual tanks when i start it hot on the front tank it shakes and skips like hell but if i just flip the tank switch to the rear tank the truck smoothes right out compared fuel pressure between frt and rear tank and frt is 7lbs lower also if i reset the ck engine light and just run on the rear tank the truck runs fine and never sets the codes or light again hope this helps Irv
Old 06-20-2010, 02:44 PM
Quote:
Dads truck does it on both tanks. the thermostat only climbs about a quarter of the way up and his fuel mileage has gone to hell in a hand basket. its agrivating as hell
Old 02-17-2011, 02:05 PM
1996cyl 1996cyl is offline
1996cyl is starting off with a positive reputation.
Did you ever figure out the problem? We have had a couple of warm days here this past week in MD and my 96 with 144k is starting to do the same thing! Won't start after being run unless I gas it, but if it's been sittin it'll start fine. I was thinkin fuel pressure regulator but I don't just want to throw parts at it and not solve the problem. I appreciate any help. Yes I know this is an old thread, just curious to see if the problem was ever solved before I start a new thread.
1996cyl
In the couple months I have owned this truck it has caused nothing but problems and an empty pocket. I bought a six for reliability...
Rough Idle and Engine Light mwoolard1912 1997 - 2003 F150 7 12-24-2016 12:23 AM
P0174 issues junior-f250 Modular V8 (4.6L, 5.4L) 3 02-23-2015 08:26 AM
2002 F-150 5.4 P0174 Too Lean TMalski 1997 - 2003 F150 1 03-18-2013 08:14 PM
2001 F-250 4x4 5.4 lean code troubles TheBlueMule 1999 to 2016 Super Duty 10 10-21-2011 10:05 PM
p0172 & p0174 ajm859830 1997 - 2003 F150 11 12-06-2010 01:37 PM
Tags
150, 1996, 300, 96, code, cyl, f150, ford, hard, hot, lean, po171, po174, start, starting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
