1996 F150 hard start when warm. P0171 and P0174
Old 02-19-2011, 10:07 PM
ididntdoit89's Avatar
ididntdoit89
ididntdoit89 is offline
it is the fuel pump... you need a new one, not the auto zone one but either a motorcraft or the dealership one.
Old 06-30-2011, 01:15 PM
aragan's Avatar
aragan
aragan is offline
I've had the same problem with my '96 F150 4.9 with duel tanks, but the problem is when warm starting from the rear tank only. If I flip the tank switch to the front tank, it runs fine. Befor I realized it only had warm start problems on the rear tank, a shop replaced my distibutor, repaired a vacuum leak but a smoker revealed no more leaks. Then when we knew it was a rear tank related problem, they replaced the rear fuel pump, but it still sounds like it's starving for gas on a rear tank warm start???? Any suggestions?
Old 02-03-2014, 09:16 PM
sandkpatterson's Avatar
sandkpatterson
sandkpatterson is offline
Tree Vacuum
Does anyone know the name of the vacuum tube in the intake manifold is called? Auto Zone can't find it but my power brake booster is plugged into it and fuel pressure regulator is plugged into it. Like to replace it but it's not called a tree vacuum at the store. Help!!
Old 03-25-2014, 08:11 AM
frankt9317's Avatar
frankt9317
frankt9317 is offline
Originally Posted by Irv Nichols
I have the same pickup with the same problem but my truck has dual tanks when i start it hot on the front tank it shakes and skips like hell but if i just flip the tank switch to the rear tank the truck smoothes right out compared fuel pressure between frt and rear tank and frt is 7lbs lower also if i reset the ck engine light and just run on the rear tank the truck runs fine and never sets the codes or light again hope this helps Irv
Same here, I have a 302 v8 and it does the same thing
Old 03-27-2014, 04:04 PM
silver38's Avatar
silver38
silver38 is offline
have a ford 150 v8 showing code PO 172
mwoolard1912
1997 - 2003 F150
02-20-2017 12:21 AM
jmccracken1214
09-21-2016 07:50 PM
allvol
1997 - 2003 F150
04-02-2016 01:39 PM
Dave042
1997 - 2003 F150
01-01-2016 07:14 PM
Wildboy402
2004 - 2008 F150
12-24-2015 12:42 AM
Quick Reply: 1996 F150 hard start when warm. P0171 and P0174
