1996 F150 hard start when warm. P0171 and P0174 - Page 2 - Ford Truck Enthusiasts Forums
Old 02-19-2011, 11:07 PM
ididntdoit89 ididntdoit89 is offline
ididntdoit89 is starting off with a positive reputation.
it is the fuel pump... you need a new one, not the auto zone one but either a motorcraft or the dealership one.
Old 06-30-2011, 02:15 PM
aragan aragan is offline
aragan is starting off with a positive reputation.
I've had the same problem with my '96 F150 4.9 with duel tanks, but the problem is when warm starting from the rear tank only. If I flip the tank switch to the front tank, it runs fine. Befor I realized it only had warm start problems on the rear tank, a shop replaced my distibutor, repaired a vacuum leak but a smoker revealed no more leaks. Then when we knew it was a rear tank related problem, they replaced the rear fuel pump, but it still sounds like it's starving for gas on a rear tank warm start???? Any suggestions?
Old 02-03-2014, 10:16 PM
sandkpatterson sandkpatterson is offline
sandkpatterson is starting off with a positive reputation.
Tree Vacuum
Does anyone know the name of the vacuum tube in the intake manifold is called? Auto Zone can't find it but my power brake booster is plugged into it and fuel pressure regulator is plugged into it. Like to replace it but it's not called a tree vacuum at the store. Help!!
Old 03-25-2014, 09:11 AM
frankt9317 frankt9317 is offline
frankt9317 is starting off with a positive reputation.
Quote:
Originally Posted by Irv Nichols View Post
I have the same pickup with the same problem but my truck has dual tanks when i start it hot on the front tank it shakes and skips like hell but if i just flip the tank switch to the rear tank the truck smoothes right out compared fuel pressure between frt and rear tank and frt is 7lbs lower also if i reset the ck engine light and just run on the rear tank the truck runs fine and never sets the codes or light again hope this helps Irv
Same here, I have a 302 v8 and it does the same thing
Old 03-27-2014, 05:04 PM
silver38 silver38 is offline
silver38 is starting off with a positive reputation.
have a ford 150 v8 showing code PO 172
Rough Idle and Engine Light mwoolard1912 1997 - 2003 F150 7 12-24-2016 12:23 AM
P0174 issues junior-f250 Modular V8 (4.6L, 5.4L) 3 02-23-2015 08:26 AM
2002 F-150 5.4 P0174 Too Lean TMalski 1997 - 2003 F150 1 03-18-2013 08:14 PM
2001 F-250 4x4 5.4 lean code troubles TheBlueMule 1999 to 2016 Super Duty 10 10-21-2011 10:05 PM
p0172 & p0174 ajm859830 1997 - 2003 F150 11 12-06-2010 01:37 PM
Tags
150, 1996, 300, 96, code, cyl, f150, ford, hard, hot, lean, po171, po174, start, starting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
