Need help/info on climate control problem - Page 2 - Ford Truck Enthusiasts Forums
Old 04-06-2011, 10:04 PM
50flathead's Avatar
50flathead 50flathead is offline
50flathead is starting off with a positive reputation.
Quote:
Originally Posted by Steve_Uzi View Post
What is the P/N of the new updated one? My blend door is horrible to say the least...
I have a routine I do to get it to switch the way I need it to.. but it is a PITA!
Finally.. any good online OEM Ford Truck parts sites?
OK here it is
Motorcraft 9L3Z-19E616-E
Box also has YH-1752 above the part number.
it did the trick
Old 04-14-2011, 07:00 PM
dgndngrngr84's Avatar
dgndngrngr84 dgndngrngr84 is offline
dgndngrngr84 is starting off with a positive reputation.
Quote:
Originally Posted by HomerWinzlow View Post
Ive had to replace a number of control heads in the past so it is possible to be that too, but it is much much less common. I dont know the price of the manual control head but I know some of the EATC control heads can cost over 600.00, so I would make sure that is the problem.
Just replaced the Manual Air Temp Control with one off of an 08 XLT at the junkyard for 30 bucks. I figured it was worth a try, but no dice. Just got back from a trip and it did it again. Like it was fine one minute then it goes skitso. So it must be blend door issues or some other weird electrical problem = I'll just live with it.
Old 04-20-2011, 09:22 PM
2004 super crew 2004 super crew is offline
2004 super crew is starting off with a positive reputation.
I had the same problem with my 04, i couldn't get good heat unless it was on 90 from my control panel, and my temp gauge oon my dash was going crazy I replaced the temp sensor behind the grill on the center support and it took care of the problem.
Old 02-15-2014, 03:45 PM
sillybiscuit sillybiscuit is offline
sillybiscuit is starting off with a positive reputation.
too hot or too cold,,nothing in between
Is the part in question called a blend door actuator or valve and what is the base number for the updated part x9xx-19e916-x ? Thanks in advance
Old 05-26-2014, 08:59 PM
P-Bod P-Bod is offline
P-Bod is starting off with a positive reputation.
Blend door actuator stuck on cold
A/C was stuck all the way cold. I replaced the blend door actuator this morning and it's working great again! 2007, F-150 Lariat with digital climate control. Doorman model #604-218 from AutoZone, $30. I used the 8mm wrench in the picture to remove all 3 screws and did not need to remove the passenger airbag. Those 3 screws are the hardest part of the job. If you have George Foreman-sized hands, you'll need to get someone else to help.
Update 5/29/14. The Dorman part made a loud clicking noise when it reached the high and low limits. I bought the one from the Ford dealer, 9L3Z-19E616-E, for $50. It is quiet through the full range of motion and the system works great.
View from radio opening:
View from glove box opening:
High Trans Temp-Need Help Blueh2o32 6.7L Power Stroke Diesel 11 06-27-2014 08:04 PM
Interesting EOT/ECT readings after family trip stangclassic66 6.0L Power Stroke Diesel 9 06-18-2012 09:31 PM
2008 climate control issue polaris192 1999 to 2016 Super Duty 5 04-03-2011 03:39 PM
Exterior Temp Goes up when Plow is on the Truck?? 05 CO King Ranch 1999 to 2016 Super Duty 3 12-28-2009 01:25 PM
Engine oil temp -- HIGH??? johnsjsj 1999 - 2003 7.3L Power Stroke Diesel 8 09-30-2007 12:47 AM
Tags
08, 2002, 2005, 2008, aviator, climate, control, f150, f250, ford, heater, problem, problems, temp, transport, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
