Swapping a 300-6 out of a 95 F-150 to a 91 F-250 that used to have a 5.0L, wondering if the I can use the motor mounts out of the 95 into the 91, or are the frames different?
well I can guarentee you the frames are somewhat different because I know for a fact that the newer F-150 frame is thinner and rusts easier! LOL The old F-250 will be thicker but don't know if the actual dimentions or style of mount changed from 95-91...
so to understand the pics... they just mount to the motor different, but to the chassis the same (1 stud)??? if that is the case you'd want to use the 95 mounts in the 91...
