Goodyear Duratrac pics and review!! - Page 3 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
  #31
Old 05-10-2010, 08:10 AM
aldridgec's Avatar
aldridgec aldridgec is offline
aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.
Quote:
Originally Posted by cartmanea View Post
Width does NOT determine how far they stick out, that is all in the offset and/or backspace.
Try and put a 10 inch wheel with enough backspacing to keep it flush on the truck and see what happens. You won't find such a wheel because they don't fit. This isn't a function of whether they hit the springs or rub or something, it physically doesn't fit on the truck because of the knuckle.
You are right, width doesn't determine (backspacing) if it sticks out.
However a 10 inch wide wheel that will FIT on a SUPERDUTY WILL stick out. There is no way around this. You have to go to a larger diameter wheel to have a wide tire that doesn't stick out.
Yes a 10 inch wheel with the same backspacing as an 8 inch wheel will stick out more, this is exactly what happens. You can't have enough backspacing to keep the wheel under the fender because of the steering knuckle.
Eh, sorry cranky this morn.
  #32
Old 05-10-2010, 11:00 AM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
I didn't think about the knuckle, my 10" wide wheels were 18s. Correct, given the same backspace, a 10" wide wheel will stick out further than a 8" wheel... given the same backspace. You need to look at the offset (preferred) or the backspace/width combo.
  #33
Old 05-10-2010, 01:24 PM
clintusaf's Avatar
clintusaf clintusaf is offline
clintusaf is gaining momentum as a positive member of FTE.
Yes, that is my main concern. that is why i was comptenplating going with a 16x8 to avoid the wheels sticking outside the wheel well and the offset should be closer to stock than most 16x10. I'm just not sure if only 1" wider wheel will make that much of a difference in the handling.
  #34
Old 05-10-2010, 03:29 PM
16x8 should be fine. That size is fine with my Toyo ATs and the Duratrac is a higher load tire, so should be more stable.
  #35
Old 05-10-2010, 03:50 PM
TattooJim's Avatar
TattooJim TattooJim is offline
TattooJim is starting off with a positive reputation.
Love my Duratracs. Ride is suprising quiet for the tread pattern.
  #36
Old 05-10-2010, 03:53 PM
clintusaf's Avatar
Quote:
Nice truck! what brand and size wheels do you have?
  #37
Old 05-10-2010, 04:50 PM
TattooJim's Avatar
Thanks Clint. ProComp 16X10's. I got 'em for about a hundred bucks each from 4WheelParts.com
  #38
Old 05-10-2010, 06:02 PM
clintusaf's Avatar
Did your lift change the position of your leaf spring?
Do the tires rub?
  #39
Old 05-10-2010, 06:55 PM
camodown's Avatar
camodown camodown is offline
camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.
Just figured I would throw my two cents in here. I have a set on the factory lariat wheels that are 285's and after driving 800 miles on the new tires, I have noticed most of the squirm is gone. They still have a little, but that is to be expected with a high depth low contact block tire. I am running 80/80, yes 80 front and rear and think it rides fine, so you might try to up the pressure a bit. Watch the wear pattern though. Oh, and nice pickup; looks like mine except the gold lower rockers.
  #40
Old 05-10-2010, 07:06 PM
clintusaf's Avatar
okay. good to know.
probably shouldnt put the pressure over what the tire is rated for though huh?
i have is at 62psi and they are rated for 65psi.
  #41
Old 05-10-2010, 07:32 PM
TattooJim's Avatar
Nope the springs didnt get relocated and no rub even at full lock. I researched what off-set I would need (here at FTE) and bought the corresponding spec'd wheels
  #42
Old 05-10-2010, 10:39 PM
camodown's Avatar
I must not have caught it earlier. Yeah, I am not recommending going more than the max inflation pressure on the sidewall. I was thinking those were E load range with an inflation of 80psi @ 3750lbs ground rating. My mistake.
  #43
Old 05-10-2010, 10:46 PM
clintusaf's Avatar
They are Load range E, but they are just rated for 65 PSI. Only because of the size i guess.
  #44
Old 05-26-2010, 09:10 PM
clintusaf's Avatar
Update:
I finally checked my tire pressure today (should've checked right after mounting), and found the front to be 60 psi and the rear to be 80 psi. i guess sears went off the door sticker instead of the tire. After getting them to 65, i noticed a lot better handling and less roll. Also, these are great on wet pavement, which was one of my main concerns. I can damn near floor it froma dead stop and they dont lose traction. Still don't have enough miles to comment on wear. Also, after further inspection, i notice that they rub on the driver's side plastic liner in the rear. easily fixed with some minor trimming. I still love the tires though. I am glad I went with the 315's instead of the 285's. With my truck being leveled, 285's just looked too small for my liking.
  #45
Old 05-26-2010, 09:19 PM
Evan99's Avatar
Evan99 Evan99 is offline
Evan99 is starting off with a positive reputation.
Im thinking about getting these good review!
pic test Zeat User Gallery & Picture Display 0 10-21-2012 08:36 AM
NSRA Northeast Nationals Show Pictures GreatNorthWoods 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 10-10-2012 09:46 AM
All Cleaned Up... WARNING Lots of Pics. cdrmotorsports 1999 to 2016 Super Duty 22 09-03-2010 12:02 PM
Pics of new fox dual stabilizers divedeep1 1999 to 2016 Super Duty 9 05-04-2010 01:47 PM
Dual exhaust pics Brown Falcon 1994.5 - 1997 7.3L Power Stroke Diesel 7 07-12-2009 08:50 AM
Tags
duratrac, duratracs, duty, expedition, f150, f250, f350, good, goodyear, mud, performancepart4truckscom, pics, super, tire, trucks, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
