Oil cooler question
Oil cooler question
The oil cooler on my 7.3 IDI sprung a leak this week. Trying to weld the pinhole while still on the truck didn't work out too well (couldn't get it clean enough to get a tack over the pinhole - kept spurting)...
Looking for a replacement cooling section (headers look to be in good shape). I know I'll need o-rings and gaskets from the stealership.
I found a "late mode 6.9 IDI oil cooler" but the guy doesn't know how many o-rings it takes because it still has the headers attached.
Questions: when did the cooler change from a 6 o-ring setup to a 4 o-ring setup? Even if it is 6 o-rings, would this setup bolt right up to my 7.3 (I'd rebuild to get new o-rings in there if I did this)? Any other advice?
Oil cooler rebuild parts
Mine has been leaking for some time and I am getting ready to fix it.
Thanks,
Chris
Here's the parts numbers:
2 - Oil cooler O rings Ford 1C3Z-6K649-BA
2 - Oil cooler O rings Ford 1C3Z-6C610-BA
1 - Oil cooler gasket Ford E3TZ-6A636-G
1 - Oil cooler gasket Ford E3TZ-6A636-H
International part #s (bag of 2 rings)
-thicker ring 1804414C1
-thinner ring 1807563C1
gasket 1804378C2
gasket 1804377C4
Oh!! Also, if you go to International, make sure you get the 'Ford' gasket, and not the International one. Apparently there was a slightly different gasket used on one model of International that they sometimes confuse witht he Ford one, and they are different enough it won't work. (Never saw the different gasket, just going from what the parts guys told me at IH when I recently picked up gaskets and o-rings for a cooler.)
gasket 1804378C2
gasket 1804377C4
gasket 1804378C2
gasket 1804377C4
gasket 1804378C2
gasket 1804377C4
on
There is a local company that specializes in o-rings that I am rather close with, as soon as get my hands on these o-rings I plan on having them match them up and get me some Vitons.
There is no IH dealer within two hours one way, local Ford dealer doesn't have them and won't look them up, truck is to old ... In their words!
-Enjoy
fh : )_~
-Enjoy
fh : )_~
