Exhaust question
If that will reduce back pressure and help the engine to function better without the expense and trouble of headers and the more expensive and tricked out exhaust systems, then that seems the most sensible way to go. I want to spend what is necessary to remove the body rust permanently, repaint the truck, and I am in process advancing the cam to non-Califonia factory specs.
The use I will make of my truck makes the expense of aluminum heads, 4bbl intake, cam, and headers for just cruising down the highway and four wheeling out to hunting sites seem to be money spent that could go for gas. if you have any suggestions for where to go to buy aluminized exhaust pipes to do what I described please let me know. thanks
It will actually work better if you dump as soon as possible after the muffler but thats a call you have to make for what your looking for and sound control.
Of course this is for stock mani's. I use an H pipe and if you do connect as close as you can (stuff in the way) and no more than 1 size smaller.
You might get better performance by going with a 2 (2.5) into one y (3" out) with a high flow muff, 3"" into 3" out the tail. These systems work with differant physics and scavange like crazy. They can sound bad *** too. Scavanging can massivly increase air flow through the carb.
My 2 cents.
You can't flow more than your smallest restriction. Also you will loose exhaust velocity and this will cool the gases and cause undue condensation in the pipes (rust) In addition the loss of velocity will kill your scavanging effect and the added cooled gasses are heavy and will cause additional back pressure trying to push the heavier charge out. You could increase to 3" at the muffler to reduce muffler restriction. Some say reduce 1 size for the tail pipe and some say go bigger. My opinnion is to increase at the muffler and stay the same going out to maintain velocity and scavanging.
My 2 cents.
My 2 cents.
clhart426
43
09-09-2019 11:12 PM
FordYoungGun35
12-10-2012 01:24 PM
James Gatling
1983 - 2012 Ranger & B-Series
01-14-2000 05:48 PM
