Disc brakes instead of drums - Ford Truck Enthusiasts Forums
Old 05-05-2010, 03:00 PM
Callantom Callantom is offline
Callantom is starting off with a positive reputation.
I have a 1993 Ford XLT F 350 4X4, crew cab, that has drum brakes on the rear and was trying to find out how to change this over to disc brakes. Has anyone done this and how expensive would it be? Thanks, Tom.
Old 05-05-2010, 03:45 PM
Virto's Avatar
Virto Virto is offline
Virto has a good reputation on FTE.Virto has a good reputation on FTE.Virto has a good reputation on FTE.
You'd pretty much have to fab everything up yourself, for practically no increase (if any) in stability or stopping power. Lots of labor, lots of trial and error and probably a healthy expense.
The vast majority of the braking in these trucks is handled up front. Upgrading those to larger discs and calipers might be a better use of money if you really want to spend on brakes.
Properly installed and adjusted rear drums are very effective. If you're having trouble with them, you might want to get them checked out.
Old 05-05-2010, 04:50 PM
Conanski's Avatar
Conanski Conanski is online now
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Maybe look for a complete disk rear end from a newer truck to swap in.
I'm not a fan of the drum brakes on these trucks either.. they never stay properly adjusted for very long and the additional rear brake power that disks provide is benificial when towing or carrying a heavy load.
Old 05-05-2010, 05:11 PM
86F150302's Avatar
86F150302 86F150302 is offline
86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.
^^^ What he said.
Old 05-05-2010, 05:51 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
do a search.
covered every few months and all come to same conclusion: leave well enough alone.
Old 05-05-2010, 06:24 PM
DBGrif91's Avatar
DBGrif91 DBGrif91 is offline
DBGrif91 is gaining momentum as a positive member of FTE.DBGrif91 is gaining momentum as a positive member of FTE.
I was having problems with my rear brakes not staying adjusted and then I changed out the self adjusting cable. I was surprised- even tho the old cable seemed tight, a new cable made a big difference. But that's on my 91 F150- and I don't do a lot of towing/hauling with it.
Old 05-06-2010, 06:00 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
Like everyone else said, its a waste of time and cash. There will be little to no gain.
Old 05-06-2010, 09:00 AM
nstueve's Avatar
nstueve nstueve is offline
nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.nstueve has a great reputation on FTE.
I'd go with getting drilled and slotted rotors and a good set of pads for the front... It's the most effective upgrade you can do!
Old 05-06-2010, 11:00 AM
SaikotikGunman's Avatar
SaikotikGunman SaikotikGunman is offline
SaikotikGunman is gaining momentum as a positive member of FTE.
TexasGuy is probably right, but every time I go to the salvage yard and walk past a newer super duty with rear discs and the same gears as my truck, I think to myself, "I wonder what he wants for that axle..."
Old 05-06-2010, 11:03 AM
zxwut?'s Avatar
zxwut? zxwut? is offline
zxwut? is gaining momentum as a positive member of FTE.zxwut? is gaining momentum as a positive member of FTE.
Quote:
Drilled and slotted rotors won't provide more braking force under normal use unless they are larger than what you started with with better calipers.
Old 05-06-2010, 12:47 PM
nstueve's Avatar
sorry I thought better calipers and larger than stock rotors was obvious... I'll be more clear next time.
Old 05-06-2010, 01:59 PM
Quote:
Less surface area... so actually LESS braking power under normal conditions.
Old 05-06-2010, 02:15 PM
jplinville's Avatar
jplinville jplinville is offline
jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.
Quote:
...but it keeps the pads and calipers cool during operation, so less chance of brake fluid heating up and failing.
Old 05-06-2010, 02:16 PM
nstueve's Avatar
Yes but they vent the gas, dust, and heat out so the pads are more effective... And you have better "bite" on the rotor with your pads and the slots and drilled holes constantly sand off a little of your pads so they are fresh when you use them... IE: Not having a bunch of road dust and break pad debris built up in them... come on guy
Old 05-06-2010, 02:20 PM
nstueve's Avatar
Typically there are 5 upgrades to breaks...
1.) better pads for a better bite on the disk
2.) better disks to keep pads clean and cool for better operation
3.) better calipers to help force the pads down harder on the disk
4.) better break lines
5.) power multiplier that adds extra force to when you put your foot down
Eaton 17-a disc brake swap skheemer Large Truck 6 09-12-2016 06:12 AM
4 wheel disc brakes for 76 highboy... Catanna69 1973 - 1979 F-100 & Larger F-Series Trucks 15 08-29-2016 08:52 PM
highboy drum to disk conversion catbird7 1973 - 1979 F-100 & Larger F-Series Trucks 9 05-15-2011 02:13 AM
1975 F250 Dana 60 Drum to Disc? HOW! castone001 1973 - 1979 F-100 & Larger F-Series Trucks 9 04-18-2009 01:13 AM
drum to disc swap??? bigmerl52 1967 - 1972 F-100 & Larger F-Series Trucks 2 12-19-2000 05:07 PM
Tags
1987, 1990, 4x4, brake, brakes, disc, disk, drum, end, f150, ford, front, rear, swap, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
