Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-05-2010, 02:51 PM
elmonto elmonto is offline
Garage is empty, add now
elmonto is starting off with a positive reputation.
66 falcon van help?
I just got a 66 falcon van in great condition and i need some help tryingto figure out the engine. Its an I6 with a tag that reads Y39206 or Y39306 the third to last number is smudged. The serial number in the door jam says E12TH247657, any help would be awesome.
  #2 (permalink)
Old 05-05-2010, 02:58 PM
jschira jschira is offline
jschira is gaining momentum as a positive member of FTE.
Is the valve cover sort of square in x-section or more rounded?
__________________
63 Falcon Deluxe Club Wagon
10 F250 Lariat 6.4L
  #3 (permalink)
Old 05-07-2010, 12:34 AM
66gpw's Avatar
66gpw 66gpw is offline
66gpw has a good reputation on FTE.66gpw has a good reputation on FTE.
The T stands for a 170 engine. E12 is club van. H for Lorain plant. The others are sequential numbers representing manufactured date. These numbers say the van was built in 1962 .
The door could of been changed over the years and an old tag left on. If you look at the back inside of the van where there is a support member behind the taillights. One of these will have the original serial number and give you the proper info for engine and years. It is stampped right into the metal plate support. The other place to look is under the lip of the doghouse. This requires removing the doghouse and the sealant to the floor to see the serial number agin on the floor lip unde the doghouse.
__________________
64 Econoline Truck.
67 Econoline truck
85 F150 Explorer XL
78 F250
  #4 (permalink)
Old 05-09-2010, 01:17 PM
I was wrong, the registration says its a 61 van. Thanks for the help.
  #5 (permalink)
Old 05-10-2010, 06:37 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by 66gpw View Post
The T stands for a 170 engine. E12 is club van. H for Lorain plant. The others are sequential numbers representing the vehicles specific serial number.
These numbers say the van was built in 1962.
247657 = Assembled December 1961 as a 1962 model.
The typical problem that affects Ford Trucks, Econolines thru 1980:
People replaced damaged left doors with used doors. 99% of the time they did not transfer the original Warranty Plate over to the replaced door.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
Tags
1966, 1967, 66, door, falcon, ford, forum, parts, problems, tag, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
