'94 F150 electrical problem - Ford Truck Enthusiasts Forums
Old 05-05-2010, 01:38 PM
MaryfPoppins's Avatar
MaryfPoppins MaryfPoppins is offline
MaryfPoppins is starting off with a positive reputation.
This is a 1994 F150 300 6cyl Auto trans.with over 200,000 miles. My daughter drove it aprox. 1.5 miles this AM. The truck died, no sputter first. Tried to restart, motor turned over but no start. Noticed grey smoke coming from the e- brake pedal area when she went to pull the latch for the hood. No smoke in engine compartment or smell of elec. burning. Electrical smell strong in cab, but with inspection no obvious burned or melted wires or components. I tested all fuses in dash and under hood. They are all good and correct size. She normally can hear her fuel pump before starting, but couldn't hear it after it died and she tried to restart the truck. Any ideas would be most appreciated. If it was simply the in tank fuel pump I can change that. The electrical issue is worrisome. Thankyou for your help.
Old 05-05-2010, 01:42 PM
Hitokori's Avatar
Hitokori Hitokori is offline
Hitokori is gaining momentum as a positive member of FTE.
ford used a pump on the frame *roughly under the e-brake area* and one in tanks
the one on the frame is probably burned up
Old 05-05-2010, 02:32 PM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
No fuel pump on the frame in 1994.
Sounds like the Computer burned up.
Not hard to change.
Disconnect the battery then:
Just unplug it (10 mm bolt in center) and take it out between the fender and inter fender.
It is located behind the e- brake pedal in the kick panel but has to come out from under the hood through the fender.
Old 05-05-2010, 03:28 PM
Subford,
Thankyou for your fast reply. Of course I have a question or two. If it is the computer why would it burn up and is there any way to check it? I have another 1994 F150 here with the same motor ( timing gear broke), but it's a 5spd manual. Will the computers be the same? The other option I have is a 1994 Auto trans with a 351.
Thanks Beth
Old 05-05-2010, 03:41 PM
Virto's Avatar
Virto Virto is offline
Virto has a good reputation on FTE.Virto has a good reputation on FTE.Virto has a good reputation on FTE.
The 300 won't run on a computer for a 302/351, that I'm aware of. The larger issue is that you have an electronic automatic, probably E4OD, that is controlled by the ECC.
You can connect the computer from the other 300ci truck and see if the engine fires, that way you'll know if an issue with the ECC, but you won't be able to drive it without the correct computer in the truck.
Old 05-05-2010, 07:19 PM
subford's Avatar
Quote:
Originally Posted by MaryfPoppins View Post
Subford,
Yes take it out and open it up and I am sure it will be obvious.
You give a hint that your truck is and Automatic so you can use it to see if the engine starts but do not try to drive it as it will not shift the transmission as Virto saying.
So NO they are not the same.
Thanks Beth
That one will not work at all.
Old 05-05-2010, 08:09 PM
I will work on this more tomorrow as daylight is fading. Do I have to be concerned about burning up the next computer? Anything I need to check to find out why this one burned up?
Thanks
Old 05-05-2010, 09:36 PM
subford's Avatar
Most of the time this happens when someone washes the engine compartment. They get water in the computer plug and the grease has dried out and it shorts there.
For the most part the computer is a grounding device that either grounds a solenoid or a relay. It also outputs a 5 Volt DC supply to some sensors and monitors the input back from all of its sensors.
This makes it very hard for something outside the computer to do it any harm other than too high a voltage. If the alternator puts out too high DC voltage then it can blow something in the computer.
The caps in the computer can also short with age and cause it to burn some chips.
Most of the time when one burns and it was not pressure washed the owner will look and look and not find anything wrong, then they will replace the computer and have no fruther problems with it.
There are no guarantees as yours could do something different but if you buy one from an auto parts store and it does not work out from the reports I hear they will replace it again.
Old 05-07-2010, 11:27 AM
subford,
You were correct that once I opened it the problem would be obvious. No pressure washing done so I am gonna assume it was just it's time to go ( I hope ). Now I just have to find a new one that doesn't break the bank. I truly appreciate all the help.
Thankyou Beth
Old 05-07-2010, 11:45 AM
subford's Avatar
You can take the number off of it and call around to a few salvage yard for one or look on ebay for one.
The number you are looking for is the drawing number that Ford puts on it.
It will start with an F3 or F4 more than likely.
Ex. = F4TF-12A650-APC
If you look on line a lot of the sources will leave out the 12A650 and jut post Ex F4TF-APC
as all of the computers have the 12A650 in their number. So search both ways.
Old 11-10-2012, 10:03 PM
1987 ford f150 1987 ford f150 is offline
1987 ford f150 is starting off with a positive reputation.
hey i have an 87 f159 with a 5.0 . i have a problem with it .. i was pulling out of my gf driveway and had my foot to the floor and it poped under the hood and started spiting and sputering . thought i blew the motor.. so changed motor and a motor i know is good.. put it in runs the same as my old motor only stays runing if u have ur foot on peddel. any on have any ideas or advise .. ???
Old 11-11-2012, 06:35 AM
subford's Avatar
Did you use the old upper intake and sensors?
Old 11-11-2012, 10:27 AM
87 f150 problems.. need help
hey i have a 87 f150 and i have a problem ! i was pulling out of my gf drive way and had my foot to the floor and it poped under the hood and starded to spit and sputer and only runs if u have ur foot on the gas . so i changed the motor and one i know is good and .. it rund the same way as my other motor ! any one got any ideas ?! please
Old 11-11-2012, 11:08 AM
yes cuz the motor put in it was out of cop car and the intakes wher different so i put my old intake and plenum on the new motor .
Old 11-11-2012, 03:00 PM
any idaes ?
460 EFI Suddenly died, burning smell, cranks but no start, no fuel pump noise, no spark 1995F150XLT4x4 1987 - 1996 F150 & Larger F-Series Trucks 21 10-09-2016 07:10 PM
F150 Starter circuit electrical: burnt ECM, 2 starters, 1 starter relay bl1989 1987 - 1996 F150 & Larger F-Series Trucks 4 07-07-2016 03:02 AM
Resistor wire smoking hot/no fuel pressure Lngbeard 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 04-29-2016 11:24 AM
Help my 91 f450 7.3 idi died while driving getsometowing Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 01-01-2015 12:34 PM
Truck won't start papadelogan 1999 - 2003 7.3L Power Stroke Diesel 107 01-11-2008 08:59 AM
Tags
1990, 1994, 300, 94, automatic, check, computer, electrical, f150, ford, issue, location, problems, smoked, truck, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
