Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1966 F-100 & Larger F-Series Trucks Discuss the Slick Sixties Ford Truck SPONSORED BY:
  #1 (permalink)
Old 05-05-2010, 10:43 AM
PawPaw's '66 PawPaw's '66 is offline
Garage is empty, add now
PawPaw's '66 is starting off with a positive reputation.
2 barrel carb problem
I just got through rebuilding the carb on my truck (66 f100 with a 352) and I am still having one of the problems I had before the rebuild. It starts and runs great but when you press the pedal it stalls like it won't take the gas. If you pedal it a little and kinda feather the gas it will take it and rev up but once it idles back down it has the same problem. Any ideas? Thanks guys.
  #2 (permalink)
Old 05-05-2010, 01:48 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Typical Auto-Lite/Motorcraft 2V carb problem.
Bogging down, stumbling, hesitating from a dead stop or when accelerating at speed: Defective accelerator pump diaphram and check valve.
Yes, you rebuilt the carb, and you prolly replaced the diaphram, but what about the check valve?
The check valve fits behind the diaphram, has a tiny nipple on one side that fits into a hole in the carb body. This nipple is notorious for snapping off...and because of this, you have to be very careful when installing it.
You replaced both parts, but while they were new...how old were they?
Ozone, humidity in the air causes these parts to harden up...even when in a box, so depending on how long the parts sat on a shelf, one or both could be defective.
Behind the cover on the front of the carb, between it and the diaphram...is a coil spring.
Is it still there? People are unware of this spring...remove the cover without paying attention, which causes the coil spring to fly out.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #3 (permalink)
Old 05-05-2010, 02:14 PM
First of all thanks for the reply ND. The check valve is the RED rubber piece that can be stubborn to put in?
Quote:
how old were they
That I don't know. The small pieces were in sealed plastic if that makes a difference.
Is it still there
Yes it is, I am sure.
  #4 (permalink)
Old 05-05-2010, 02:26 PM
Ford Parts Guru
2013 Ford Escape
The check valve is the small round RED rubber piece that can be stubborn to put in.
It should make a difference, but if there's a tiny hole in the plastic bag...
The diaphram is the same 1962/74 (C4AZ9B559A-Motorcraft CM463). 1975/79 is different. The check valve is the same 1962/79 (C4AZ9576A-Motorcraft CM825).
The same carb kit fits all 1962/74 Passenger Cars, F100/350's, Bronco's & Econoline 2V Auto-Lite/Motorcraft carbs (D4AZ9A586A-Motorcraft CT499D).
1975/79, there's a gazillion different kits.
__________________
  #5 (permalink)
Old 05-05-2010, 03:34 PM
Well I guess I will do it again cause it is obviously what is giving me problems. Fortunately the kits are cheap!!
  #6 (permalink)
Old 05-05-2010, 05:20 PM
camperspecial65 camperspecial65 is offline
camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.
When I did mine the diaphram had a long pigtail that you could grab with a pair of needlenose pliers and pull through until its seated. Then you just snip the end of the tail off and its done...Also I THINK the diaphrams only go in properly one way...Also, the diaphram cover has the arm with 2 holes in it...make sure the activating rod is in the INSIDE hole.
What brand of kit did you get ??? The Motorcraft kit is still available from Ford last I checked...CT499D p/n D4AZ9A586A
- cs65
  #7 (permalink)
Old 05-05-2010, 05:33 PM
Ford Parts Guru
2013 Ford Escape
Quote:
You are describing the check valve, not the diaphram.
Take care when doing this...you pinch that pigtail too hard, the tit snaps off. Then you gotta make a RT to the parts store to get another.
What brand of kit did you get ??? The Motorcraft kit is still available from Ford...
D4AZ9A586A (Motorcraft CT499D)
MSRP: $33.42 // FTE Ford Dealer Parts Dept sponsor PARTSGUYED.COM price: $20.05.
Parts Guy Ed = Ed Olson, parts manager of Horizon Ford in Seattle (Tukwila) WA
The diaphram has a circular piece of metal in its center. It only fits in one way, because the coil spring butts up against it.
__________________
  #8 (permalink)
Old 05-05-2010, 05:41 PM
Thanks for the correction Bill...The price amazes me...alot cheaper then when I did mine.
- cs65
  #9 (permalink)
Old 05-05-2010, 05:57 PM
312 312 is offline
312 is starting off with a positive reputation.
did you blow the passages out with compressed air.i never seen a kit dry out.you either made a mistake putting it together or its plugged or has a vacuum leak.
  #10 (permalink)
Old 05-05-2010, 06:34 PM
Be careful here also as theres a couple of check ***** as I recall...One problem I did have was getting the float spring in correctly...I had to take the carb back off and bck to the bench and pulled the top off. My issue was it would only run off of a bottle feeding from above it though...but that is a tricky lil pup getting it right is a make or break thing as I found out. If you happen to have a spare around, pull the top off and have a looksee if you need to.
- cs65
As to the pigtail snipping...the tail is about an inch long...I left about 1/4" on it.
  #11 (permalink)
Old 05-05-2010, 09:00 PM
KC63's Avatar
KC63 KC63 is offline
1963 Ford F-100
KC63 is starting off with a positive reputation.
where does the check valve go on this one? carb tag says C 3TF H
I've been having these same problems. idles but dies w/ any throttle.
diaphragm looks good...
Click the image to open in full size.
  #12 (permalink)
Old 05-05-2010, 10:53 PM
tbm3fan's Avatar
tbm3fan tbm3fan is offline
tbm3fan has a great reputation on FTE.tbm3fan has a great reputation on FTE.tbm3fan has a great reputation on FTE.tbm3fan has a great reputation on FTE.tbm3fan has a great reputation on FTE.tbm3fan has a great reputation on FTE.
Since the OP has a 66 352 with a Autolite 2100 then there is only 1 little check ball. I just rebuilt 3 of these carbs as spares and have them on the shelf bagged. The check ball is in the venturi booster with a short rod on top of it and then the hollow screw over that.
If the check valve is good and the diaphragm is in the correct way with the spring then , as someone asked, are all the narrow passageways blown out. There are a bunch of them and when you blip the throttle you are going to give a shot of gas through the venturi booster. Take that thing off and notice all those little holes that bring gas. You can soak a carb all you want but those passageways need to be blown out one way or another. I even use a small hypodermic syringe that I fill with carb cleaner and inject it through every opening. Should come out another opening freely.
__________________
Mike
1965 F-100 360-2V
1968 Cougar 302-4V
1968 Mustang 289-2V
1967 Parklane 410-4V / 1973 Dodge Polara
1943 USS Hornet/1945 TBM3E Avenger
  #13 (permalink)
Old 05-06-2010, 12:00 AM
KC63's Avatar
1963 Ford F-100
Mike, are you sayin' take the brown part out of the acc. pump? does the part in middle (with the 3 tabs)unscrew?
  #14 (permalink)
Old 05-06-2010, 12:27 AM
tbm3fan's Avatar
Quote:
To be honest your carb doesn't look like any of my 2100's from the front as per your picture. All mine look like this:
__________________
Mike
1965 F-100 360-2V
1968 Cougar 302-4V
1968 Mustang 289-2V
  #15 (permalink)
Old 05-06-2010, 12:45 AM
KC63's Avatar
1963 Ford F-100
this is an old post that makes me sure it's original. does that mean it's not a 2100? if this carb doesn't have a red rubber check valve but has the same issue as described in this thread then what? must be something else.
tag is C3TF H B 3GC. the 3 I'm assuming is for '63
Quote:
Originally Posted by 64F-100 View Post
The tag on my carb reads: C3TF H B 4CC
Does it sound like this is the correct carb on this truck?
Yes.
C3TF-H = C3TZ-9510-U .. Carburetor (Motorcraft CA-271)
1957/63 & 1964/72 Ford Truck Parts Catalogs / Carburetor Parts List #14A
Original application: 1963/64 F100/700 292.
D4AZ-9A586-A .. Carb Kit (Motorcraft CT-499-D)
78-9533-B .. Carb Jet ~ #48: 0-5,000 ft. (Motorcraft CJ-55)
C1AZ-9533-B .. Carb Jet ~ #46: 5,000-10,000 ft. (Motorcraft CJ-20)
C1AZ-9533-F .. Carb Jet ~ #44: 10,000-15,000 ft. (Motorcraft CJ-24)
__________________
Bill / Retired Ford Parts Manager // Part number research: 1928/2002 Passenger Cars & Trucks.
Tags
1966, 2100, 289, 292, 2v, barrel, break, c3tf, c3tfh, carb, carbs, carburetor, ford, motorcraft, problems, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
