Power door lock problem 2005 Crew Cab FX4 - Ford Truck Enthusiasts Forums
Old 05-05-2010, 11:27 AM
RobertsRedFX4 RobertsRedFX4 is offline
RobertsRedFX4 is starting off with a positive reputation.
I have a 2005 Crew Cab FX4 with a driver side power door lock problem, any suggestions on a fix would be appreciated. Here's the problem....
The power door lock on the front driver side will lock the door locks, but will not unlock them. When using the passenger side controls or the keyless remote, the locks work fine, they lock and unlock perfectly.
I have already tested the driver side toggle switch by swapping the switch with the passenger side, and the problem remains the same, so I know it's not a switch problem.
If the driver toggle switch is hooked up to the passenger side, the switch works perfectly. If the passenger toggle switch is hooked up to the driver side, the unlock will not work once again.
The locks are not binding in any way as when using the passenger side switch or the remote, the locks go up and down very quickly and sound very strong.
The problem happens with the ignition on or off.
Any sugestions???
Thanks,
driver side switch won't lock doors noplugs4me 1999 to 2016 Super Duty 1 06-20-2015 05:47 PM
power door lock wire diagram 1988 f-250 Duramaxfanatic1 1987 - 1996 F150 & Larger F-Series Trucks 3 03-20-2015 07:51 PM
ford f350 2003 crew cab power lock problems fruitcake1234 1999 to 2016 Super Duty 1 10-15-2013 07:04 PM
2003 Ford Power Door Unlock detill Explorer, Sport Trac, Mountaineer & Aviator 2 08-29-2013 07:23 AM
Power Door Lock 97 Explorer jonboy88 Explorer, Sport Trac, Mountaineer & Aviator 20 06-12-2006 04:35 PM
Tags
2005, 2007, codes, door, drivers, electric, f150, ford, fx4, lock, locks, power, problems, setting, side, taurus, unlock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
