Thanks. F100 inline 6 - Ford Truck Enthusiasts Forums
Old 05-05-2010, 12:46 AM
Kenekeb Kenekeb is offline
Kenekeb is starting off with a positive reputation.
Aloha.
Thanks to all that helped. I got the engine running, but when I give it gas i can here a lot of sucking noise comming from the carberator and it jumps and spits and dies if I dont let off the gas.
How can I tell what carberator is on my truck. I am pretty sure it is a stock 1barrel
Old 05-05-2010, 12:55 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by Kenekeb View Post
Aloha.
How can I tell what carberator is on my truck. I am pretty sure it is a stock 1 barrel
What year is the truck?
Old 05-05-2010, 12:59 AM
1966 ford f100 inline 6 300 w/MT
Old 05-05-2010, 03:59 AM
Auto-Lite/Motorcraft 1100 1V carburetor.
Old 05-05-2010, 10:27 AM
hivoltj's Avatar
hivoltj hivoltj is offline
hivoltj is gaining momentum as a positive member of FTE.
Glad you got it running! A couple things to think about :
Check fuel pressure - usually 5-8 PSI for carb'd stuff
how old is the gas?
how long has it been sitting? carb might have plugged up passages
what condition is the ignition system in? Points, wires, plugs, cap, rotor, etc.
1989 F350 460 FI, to Carberator? Floor-N-It 1987 - 1996 F150 & Larger F-Series Trucks 10 01-12-2011 08:45 PM
Broke Fuel Filter JRon 1973 - 1979 F-100 & Larger F-Series Trucks 10 04-17-2010 12:19 PM
Carberator replacement on 1976 460 engine Lobo33 1973 - 1979 F-100 & Larger F-Series Trucks 7 01-05-2005 04:41 PM
Swapping 302 EFI system for carberator Joe7qb 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 02-22-2004 02:16 PM
...carberation F100DREAM FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 01-16-2004 07:13 PM
Tags
1966, 66, carburetor, f100, ford, ford100inline61978, inline, inline6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
