Dash Bezel
Dash Bezel
Need to know if a 67 dash bezel will fit in my 63. Im asking because my Speedo is messed up and none of the gauges work. I was on EBAY and bought the 5 gages from a 1963 F100 schoolbus for $15 bucks. It has five gages, Speedo, fuel, oil, temp, amp meter that all work. Was wanting to put them all this 67 dash bezel with the factory 5 holes and if it would fit. Im not sure after looking at pics of mine and this one on ebay it looks like mine from my 63 is a little differance. Any ideas or advise? Thanks
The 1967 F100/350 instrument cluster bezel is totally different than any 1961/66 F100/1100 because the dash is different.
This bezel is plastic, uses a sweep speedometer and has 2 (or 4 with optional oil/amp gauges) rectangular cutouts for the gauges.
The instrument cluster bezels used on F500 and larger trucks are the same 1961/69. These can be retrofitted into 1961/66 F100/350's.
