bushings for the door latch? - Ford Truck Enthusiasts Forums
Old 05-04-2010, 11:18 PM
Cody J Cody J is offline
Cody J is starting off with a positive reputation.
I have a 76 f250 with alot of play in the doors when they are closed. The previous owner had wrapped electrical tape around the post on the cab to keep the door from bouncing around going down the road. Does anyone know if there should be any bushings on the rod on the cab that the door latch closes around, or is it just a case of worn parts? thanks
Old 05-04-2010, 11:30 PM
bucks77ford's Avatar
bucks77ford bucks77ford is offline
bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.
You probably need a door hinge pin repair kit like this one that you can usually get at most parts stores. That will take the play out of the door hinges. When the doors are open, can you move them up and down and see the hinges move?
Door Hinge Repair Kit
You also may need a new door striker bolt that you can also get at most parts stores. That striker bolt is somewhat adjustable, so you may not need it once you get the door hinges repaired.
http://broncograveyard.com/bronco/i-...ker-plate.html
Old 09-11-2010, 03:01 AM
shooter47989 shooter47989 is offline
shooter47989 is starting off with a positive reputation.
door latch bushing
there is a plastic bushing in the door striker.
Old 09-11-2010, 09:45 AM
lxlmariuslxl's Avatar
lxlmariuslxl lxlmariuslxl is offline
lxlmariuslxl is starting off with a positive reputation.
I went to advance auto and got the striker bushings for a mid 90's explorer and they are working great. Package came with 2 different styles I just matched it up. For both doors It was under 4 bucks.
Old 09-11-2010, 09:54 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by Cody J View Post
I have a 76 f250 with alot of play in the doors when they are closed. The previous owner had wrapped electrical tape around the post (striker plate) on the cab to keep the door from bouncing around going down the road.
Welcome to FTE
You are speaking of the striker plates, which thread into the door post. The striker plates have a nylon bushing on them that cracks apart, then falls off. The bushing cannot be replaced, as there's no way to R&R it.
D2AZ6522008A .. Striker Plate / Right/Left is the same / Available from Ford and a gazillion autoparts stores.
Fits: 1973/79 F100/880 / 1975/83 Econoline / 1978/79 Bronco, and...
Fits: 1972 LTD/Mercury Marquis/Mustang/Cougar/Torino/Montego/Pinto/Bobcat/Thunderbird/Lincoln / Used on the front & rear doors of 4 door sedans and station wagons.
Fits ALL 1973/79: Ford/Mercury/Lincoln Passenger Cars (except Maverick/Comet) / Used on the front & rear doors.
Fits: 1980/82 LTD/Crown Vic/Mercury Grand Marquis/Fairmont/Zephyr/Granada/Thunderbird/Cougar / 1980/83 Continental Mark VI / 1980/86 Lincoln Town Car / Used on the front & rear doors.
Junkyards: Rear doors get very little usage, so the striker plates are usually like new.
Old 09-11-2010, 09:59 AM
Blown 331's Avatar
Blown 331 Blown 331 is offline
Blown 331 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by NumberDummy View Post
Welcome to FTE
Thats what I thought and couldn't figure out why this is even available.
Door Striker Bushings (plastic)
Old 09-11-2010, 10:08 AM
I'm a little confused, Do the striker on the 76 doors not unbolt?
Old 09-11-2010, 10:25 AM
Ford made the puppy so the bushing cannot be replaced. I've seen some crazy things done to these puppies, but the fact of the matter is...
Since the strikers were used on the front and rear doors of a gazillion passenger cars, one trip to a junkyard will usually give you enough extras to last a millennium.
If you want branny new, it's available from Ford and every autoparts store.
The striker has threads on the end, so it threads on/off the door post. There is no bolts involved.
I'm gonna have to learn how to scan and post parts catalogs pics...or mebbe not, since I'm already besieged enough...as it is.
Old 09-11-2010, 10:31 AM
doug70 doug70 is offline
doug70 is starting off with a positive reputation.
fix
I have removed the ford striker pin and used a cutoff wheel to remove the washer and put the plastic insert in. Then made a new washer from a piece of plate and the problem is solved and it is easy to replace again in the future.
Doug
Old 09-11-2010, 10:41 AM
Why go thru all that trouble when there are a gazillion of these puppies available in junkyards, autoparts stores and from Ford?
Old 09-11-2010, 10:49 AM
simplicity
it just was easier to put some bushings in the tool box than entire strikers. Not one of Fords better ideas, but easy to work around and you can't tell by looking at it. This is not for everyone, I used an end mill to get the tolerance I wanted.
Doug
plastic door latch piece hotrod351 1987 - 1996 F150 & Larger F-Series Trucks 5 09-01-2014 09:31 PM
Drivers Door closing/latching issues pwjackson42 1994.5 - 1997 7.3L Power Stroke Diesel 5 04-10-2014 07:11 AM
Need Help!! Can't open rear doors on extended cab. hunter301 1999 to 2016 Super Duty 2 11-09-2013 10:02 PM
door latch bushings Martin Broll 1994.5 - 1997 7.3L Power Stroke Diesel 7 12-20-2010 07:50 AM
Door Rattle dhobdey1 1973 - 1979 F-100 & Larger F-Series Trucks 8 12-28-2009 02:15 PM
Tags
2001, 250, bolt, bushing, busing, door, f150, f250, ford, hinge, kit, latch, repair, striker, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
