Compressor Clutch Removal Question
'96<nobr style="font-family: verdana,geneva,lucida,'lucida grande',arial,helvetica,sans-serif;" id="itxt_nobr_0_0"></nobr> Ranger Super 3.0L V6 5 speed; about 225K miles on chassis; about 150K on engine.
Removing the A/C compressor clutch due to squeaking/screeching. Compressor is still mounted to engine bracket. Got the small bolt, plate, washer, snap ring and pulley off without problems. Looks like the electromagnet and its housing remains.
Not sure how to remove this. Seems fixed and thought I'd ask before prying and hammering on it. Anyone know the best way to remove this? (don't have the replacement part yet)
Thanks in advance.
Thanks in advance.
The only problem I'm having is the noise - squealing & screaching. Because I can make it screach whenever I turn the A/C on, focused on the clutch assy. A/C blows cold air. Think I'll clean what I have apart so far, lubricate and assemble & test.
What lubrication do you recommend? Thought about using synthetic wheel bearing grease.
Michael Ides
05-16-2010 01:49 PM
sstrunk
1983 - 2012 Ranger & B-Series
04-14-2010 02:15 PM
2001SuperDuty
03-24-2010 07:52 AM
