2 wheel drive tranny work in a 4x4 truck? - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 05-04-2010, 01:36 PM
wildstang's Avatar
wildstang wildstang is offline
VT Chapter Ldr
wildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputation
There is a good deal on e4od from a 97 2x4 diesel that I may buy for my 4x4. Will this work on my truck or is there a tail housing that can be swapped over? Thank you
Old 05-04-2010, 02:05 PM
rideracelivemx7's Avatar
rideracelivemx7 rideracelivemx7 is offline
rideracelivemx7 is starting off with a positive reputation.
no sir, the 2 wheel trannies have a difference/ longer? output shaft i do belive, you can swap them over if your real good at rebuilding the tricky *****. but in my opinon, just find a 4x4 tranny!
Midwest Dually's Avatar
Midwest Dually Midwest Dually is offline
Midwest Dually has a good reputation on FTE.Midwest Dually has a good reputation on FTE.Midwest Dually has a good reputation on FTE.
If I am not mistaken, the 2-wheel drive E4OD's dont have a transferable tail housing that can be swapped out to fit a married transfer case. Most likely if a person wants to use a 2-wheel drive transmission for their 4-wheel drive, you will have to buy a seperated transfer case (or divorced as its called) and work the bugs out on the drive line between the transmission and transfer case.
The older models (60's,70's,80's) had the option of a married unit or divorced unit. New Process made both models, and the seperated units were easier to service along with the trannys.
I pulled my E4OD 2-wheel drive out, and looking at it, I was curious if a person could add the transfer case to it. I have the E4OD with transfer. There appeared to be a huge difference between the two housings, including tranny length before mounting up to the transfer case, so much of one, that it was quite obvious that most of the transmission housing would have to be swapped if a person wanted to do this, to make it conceivable.
Old 05-04-2010, 02:06 PM
SaintITC SaintITC is offline
SaintITC has a good reputation on FTE.SaintITC has a good reputation on FTE.
I don't know , but most likely you'll need to change something. I find it hard to imagine you can simply replace the tail housing with your transfer case housing. If you have the Ford drivetrain manual there are detailed assembly drawings, if there are different parts they would be listed.
I do know the 5 spd manual tranny's are different internally - longer mainshaft for 4x4.
Good luck
Old 05-04-2010, 02:13 PM
wildstang's Avatar
VT Chapter Ldr
Damn one for sale recently rebuilt and up graded internals with torque converter for $500. Been nice to have a backup.
Old 05-04-2010, 02:42 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
A 2wd transmission will work in a 4x4 if you change the extension housing and output shaft. Both parts can be swapped. The extension housing is dead easy, the output shaft requires a complete disassembly of the transmission to swap. It can be done, but you need to know how to build an automatic trans to do it.
Old 05-04-2010, 02:59 PM
wildstang's Avatar
VT Chapter Ldr
Thanks Mark, maybe I should get it anyways and when the time comes have a shop swap them.
Old 09-13-2010, 03:27 PM
banditrocs banditrocs is offline
banditrocs is starting off with a positive reputation.
does anyone know if you can change the tail shaft on a c6 tranny, go from 4x4 to 2 wheel?
Old 09-13-2010, 09:10 PM
You can, as long as you also disassemble the transmission and change the output shaft.
Old 08-01-2016, 09:10 PM
Jabra125 Jabra125 is offline
Jabra125 is starting off with a positive reputation.
Do I pulled a transmission out of a 90 f150 two wheel drive, and it mounted up perfectly to my 89 f150 four wheel drive with only a few modifications. Everything is back together now and the truck runs, my clutch engages, but the transmission doesn't seem to want to grab a great, yet it tries to grab reverse. What's the problem here?
Old 08-01-2016, 09:50 PM
Did you change the output shaft in the transmission to a 4x4 output shaft? If not the output shaft isn't going to engage the transfer case.
Old 08-02-2016, 12:24 PM
Could the input shaft be different as well? They both came off of the 4.9 L6 engine
Old 08-02-2016, 02:33 PM
No, the input shafts are the same.
97 f-350 4x4 issues Sweeneylandscape 1994.5 - 1997 7.3L Power Stroke Diesel 3 02-15-2015 08:05 PM
Engine perch advice for FE in 4x4 fomoco3904 1973 - 1979 F-100 & Larger F-Series Trucks 5 10-16-2013 09:51 PM
4x4 to 2x4 Beamed 1987 - 1996 F150 & Larger F-Series Trucks 10 03-17-2009 12:20 PM
the ultimate ? 4x2 to 4x4 fordguy300 1987 - 1996 F150 & Larger F-Series Trucks 19 05-20-2008 10:23 PM
4x4 AOD and 4x2 AOD navyflyinggreg Clutch, Transmission, Differential, Axle & Transfer Case 2 04-24-2007 03:04 PM
Tags
4x4, 60, 73, diesel, dr, drive, f250, ford, sale, swap, trannys, trans, transmission, wheel, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
