Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 05-04-2010, 09:00 AM
scholzee scholzee is offline
Garage is empty, add now
scholzee is starting off with a positive reputation.
Advice on buying 07,08 Expedition
Currently have a 2001 EB Expedtion with 150K. We will be upgrading to an 07,08. We became acustom to the heated seats, automatic ac front and back and need a 4x4. What should I watch out for. Most xlt,s I see do not have all the options we want. Some limiteds have some options and we like the mono chromatic look. EB's seem to have all the options but we are slighly turned off be the gold plastic moulding, its much thicker than our current version. Thanks for all replies.
  #2 (permalink)
Old 05-04-2010, 12:11 PM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
check every single button and electronic feature
check every single panel for paint defects
otherwise enjoy. The EB's are great. They are essentially the Lariat models. The Limited gets all the goodies standards, and the KR gets everything + special leather.
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #3 (permalink)
Old 05-04-2010, 05:03 PM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
Heated seats and temperature controlled AC/Heat are certainly available on the XLT. Just have to order the Limited Option. I ain't paying $5000 for those features, thank you!
-- Chuck
  #4 (permalink)
Old 05-04-2010, 05:40 PM
Tylus's Avatar
Nuke Mechanic
2006 Ford F-250
all the 07+ Expy I have seen have the super duper trim pieces. i actually like them. You might find an XLT without it like a 97-02 model...but I haven't seen one yet
The A/C seats aren't worth the money IMO. They work when they feel like it, and I would rather have saved a few bucks than have them.
If you want heat/cold seats, you have to get Leather. Ford doesn't put the heat into cloth seats. So that kills every single XLT that is stock.
So now you are only able to look at EB, Limited, KR. The EB bridges the gap between XLT and Limited.
As far as rear A/C...all of them come with rear air. It just depends on the trim level if you get fancy controls or a simple twist ****...
__________________
  #5 (permalink)
Old 05-05-2010, 08:57 AM
Thanks for the tips !! Not so concerned with the AC seats but we ski and the wife likes the heated seats also helps her when her back is sore. We looked at a KR but a little to flashy for us to each their own I know they do appeal to many people. So I guess I will concentrate on EB and Limited. Any mechanical things to worry about ? On my 2001 I specifically stayed away from air suspension. I am looking at used obviously so anything that maybe a problem that crreps up on 3 or 4 yearold expeditions ?
Thanks again Everyone
  #6 (permalink)
Old 05-05-2010, 08:06 PM
clearnetedm clearnetedm is offline
clearnetedm is starting off with a positive reputation.
I think the 07's and even some earlier 08's still had some spark plug issues. Not sure when the 08 date was that they finally resolved but i'm sure there are a few threads on the subject.
I found a good post that tylus sumed up the spark plug issue:
http://www.ford-trucks.com/forums/95...a-problem.html
Quote:
Originally Posted by tylus View Post
here is the lowdown on the spark plugs from about 2000 to current
2000-2003
4.6 2v
5.4 2v
V-10
problem seemed to surface when Ford started using the PI heads. spark plugs ejected from the head due to insufficient threads in the head. repairs required either a heli-coil or insert...or a new head.
it's completely random and can happen to anyone. Some people never have it happen...and some poor *******s have it happen one after another
2004-2007(midyear)
4.6 3v
5.4 3v
spark plugs are a multiple piece design that is tack welded together. Ford also increased the threads inside the head to fix the blow-out issue...the nature of the 3v head made for an extremely small space where the plug penetrates the cylinder
carbon from the ignition process and unburnt fuel collects around the spark plug. this causes the spark plug to get caught. the tack weld breaks and the plug will come out in 2-3 pieces.
doesn't always happen...but it's a definite possibility
2008-current
4.6 3v
5.4 3v
in late 2007 Ford issued a redesigned head that went back to a traditional sparkplug.
motors built after Nov 2007 have the new design head. So if you are looking at a 2008 model Ford, you need to look at the drivers side head. it will have a build date sticker on there. You want one built after the revision was issued.
Last edited by clearnetedm; 05-05-2010 at 08:10 PM. Reason: Updated with past thread.
  #7 (permalink)
Old 05-06-2010, 02:55 AM
Tylus's Avatar
Nuke Mechanic
2006 Ford F-250
mechanically they are pretty darn solid.
the front end, t-case and motor are a direct swap from the 2003-2006 Expy and 2004-2008 F-150.
The rear end is a modified 9.75 independant suspension that is mostly the same as the 03-06 Expy...just slightly upgraded to handle the extra weight that the EL's brought to the table.
the 07+ introduced the 6 speed transmission. a very good transmission IMO. The early 07 and 08 models had older programming that caused some weird/hard shifting patterns. a subsequent PCM/TCM reflash has been issued that seems to fix this. Seems to be the only complaints I've seen about the tranny.
nothing really jumps out at me right now that you really need to be on the lookout for. the only thing I can think of is spark plugs. The 07's have that crappy design head/plug setup. But the tool to remove the broken plugs is only $100. So really a non-issue in my eyes.
think mainly the biggest thing to look out for is the prior owner themselves. with good maintenance habits, you should trouble free for quite some time.
not to mention these have a 3yr/36k bumper to bumper warranty
and
a 5yr/60,000 mile powertrain warranty
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
