Engine sputters horribly under accelaration. - Ford Truck Enthusiasts Forums
Old 05-04-2010, 01:43 AM
aiervese aiervese is offline
aiervese is starting off with a positive reputation.
I've never seen anything like this, anytime i try to accelerate the truck shakes violently and it sputters until i even out my speed. The engine light is on and says im running lean in bank 1 and 2 but i have no clue where to start with this. Any help would be awesome. thanks
Old 05-17-2010, 04:37 PM
kermitstang86's Avatar
kermitstang86 kermitstang86 is offline
kermitstang86 is starting off with a positive reputation.
I had something like that, and it turned out to be two things. 1- Bad coil pack, and 2- bad Back Pressure sensor.
Old 05-17-2010, 06:08 PM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.
Could it be starving for fuel?
Maybe a clogged fuel filter that can't keep up with fuel demands under acceleration but does OK once you get to speed?
Quick, cheap and easy to swap - it would be worth a try to eliminate a simple thing first.
Old 05-18-2010, 12:09 PM
powersmoked's Avatar
powersmoked powersmoked is offline
powersmoked is gaining momentum as a positive member of FTE.
I completely agree with BrianA..change the fuel filter and if the issue is still there look for vacuum leaks and do a fuel pressure test
Old 05-26-2010, 09:29 AM
T K T K is offline
T K is starting off with a positive reputation.
A fuel filter change is fine but I would start by checking the coil, then a compression test on all cylinders. I have found broken valve springs in the past.
Almost no power, sputters under load 76F2504x4FB 1973 - 1979 F-100 & Larger F-Series Trucks 9 11-04-2015 09:38 PM
Low RPM Sputter. bcoats75 Excursion - King of SUVs 15 10-21-2015 09:56 AM
F250 6.0 L Diesel Sputters when going up hill crisk 6.0L Power Stroke Diesel 19 04-04-2015 10:53 AM
Kohler Engine Quits when hot Nitramjr General NON-Automotive Conversation 24 09-28-2010 05:54 AM
Cruise Control Sputter Betaracer 6.0L Power Stroke Diesel 1 09-19-2005 04:56 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
2001, 250, accelerated, accelerates, accelerating, acceleration, baddly, diesel, engine, lean, running, sputters, taurus, truck, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
