where too hook up oil pressure gauge to get most..
Old 05-03-2010, 09:40 PM
78fordf150ranger's Avatar
78fordf150ranger
78fordf150ranger is offline
okay i have my oil pressure gague hooked up too the port just before the oil filter is this the best place too get a accurate reading of true oil pressure??
Old 05-04-2010, 07:35 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
If you are talking about the port right on top of the oil filter adapter, that's actually AFTER the oil filter, and is definitely the BEST place. That's between the oil filter and block's oil feed, so it's definitely exactly what is at the bearings (given that there might be some pressure drop based on passageway flow).
Old 05-13-2011, 02:52 PM
PRUSue's Avatar
PRUSue
PRUSue is offline
To revive and old thread: I have a 428FE in a 1973 F100, so the oil filter is a tight fit to start and I have to run a shorter filter than the usual stock unit. My question- I want to install an aftermarket mechanical gauge and retain my stock gauge. How should I hook this up and what additional parts do I need? Is there some kind of t-fitting to use, or another oil pressure port to plumb? Thanks!
Old 05-13-2011, 03:04 PM
Sleepy445FE's Avatar
Sleepy445FE
Sleepy445FE is offline
No t-fitting on mine. It just comes straight up off the top of the filter pad. The gauge should come with the fitting to attach the pressure hose, all you'll need is the hardware to connect this fitting to the pad. Wish I could remember just what I used but... it's been a while.
Old 05-13-2011, 03:07 PM
PRUSue's Avatar
PRUSue
PRUSue is offline
Yeah but how do you install that AND keep the factory electric sending unit?
Old 05-13-2011, 03:23 PM
Sleepy445FE
Ah, seems I skimmed over the part about keeping the factory unit. I've never done both. I would assume that you could use a t-fitting and get a reading from both. It's a closed line so the pressure doesn't have anywhere to go so it should read correct on both gauges.
Old 05-13-2011, 07:37 PM
bamaf150's Avatar
bamaf150
bamaf150 is offline
Is the stock guage mechanical or electric?
Old 05-13-2011, 09:41 PM
montana_highboy's Avatar
montana_highboy
montana_highboy is offline
Like Sleepy said, just use a T-fitting, works perfectly.
Stock gauges are electrical.
Jason Montgomery
08-22-2016 01:19 AM
joeruger509
12-09-2015 07:15 PM
tsuess
22
11-01-2014 06:23 PM
351M78
01-04-2013 11:30 AM
cornfeed
2004 - 2008 F150
12-12-2012 08:14 AM
Quick Reply: where too hook up oil pressure gauge to get most..
