Clutch Safety Switch adjustment Question - Ford Truck Enthusiasts Forums
Old 05-03-2010, 12:39 PM
csangster csangster is offline
csangster is starting off with a positive reputation.
Good day,
I own a 1994 F350 with the ZF 5-speed.
When starting the truck, I must push the clutch pedal all the way to the floor, and then a tiny bit more in order to start the truck. Is there an adjustment I can make on the clutch safety switch? Where is the clutch safety switch located?
Thanks,
Chris
Old 05-03-2010, 02:23 PM
andym's Avatar
andym andym is online now
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
Don't adjust the switch. You have worn out bushings in your clutch linkage that are causing this problem. Take care of it now before you can't start the truck at all anymore.
Old 05-03-2010, 02:40 PM
Part Number?
Quote:
Andy,
What part numbers am I looking for?
Do I need to go to the dealer to get the parts?
Thanks,
Chris
Old 05-03-2010, 02:56 PM
andym's Avatar
Quote:
Originally Posted by csangster View Post
Andy,
Thanks,
Chris
I wish I could be of more help. I've never had to fix that problem myself but I have read a few threads about it. Maybe a few searches would turn up some help for you.
Old 05-05-2010, 02:41 PM
Alvin in AZ's Avatar
Alvin in AZ Alvin in AZ is offline
Alvin in AZ is gaining momentum as a positive member of FTE.Alvin in AZ is gaining momentum as a positive member of FTE.
x2 on what Andy said but the switch is adjustable "in a way". ;)
Betcha you won't need to adjust it after fixing the wornout stuff tho! :)
...just like Andy said.
http://www.panix.com/~alvinj/file12/pushrods.jpg
See that middle pushrod and the wornout stud that went with it? :/
They are off my 188k '90 F250 parts truck.
I replaced the stud with a hunk of bolt and welded it to the crank.
The bolt was sized to fit the larger brake-pushrod to the right. :)
The brake-pushrod needed cutting off shorter and the end rounded...
http://www.panix.com/~alvinj/file12/pushrod.jpg
...that's just some careful grinding and a deburring wheel was used
to clean it up. :)
Seems to me all your parts can come from RockAuto and it's a real
good outfit too! :)
Alvin in AZ
Old 05-05-2010, 02:46 PM
New parts
Just like Andy said.
good outfit too!
to clean it up.
Alvin in AZ
I just got back from Sil Terhar Ford with a new crank and bushing. We'll see how she goes together tonight. When I looked at the rod-end last night, it didn't look like it was worn that terribly bad. I'll put a finer eye on it tonight.
Thanks,
Chris
NO clutch safety switch rick 1999 to 2016 Super Duty 5 08-18-2016 01:07 PM
79 F150 4spd clutch switch Phil Fleming 1973 - 1979 F-100 & Larger F-Series Trucks 6 06-21-2016 08:13 AM
Clutch safety starting switch brent1204 Ranger & B-Series 5 02-24-2015 10:19 PM
By-passing clutch safety switch! IDIDieselJohn 1987 - 1996 F150 & Larger F-Series Trucks 3 11-26-2013 05:23 PM
Clutch safety switch iusse? Fordownsall Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 06-10-2011 09:40 PM
Tags
1983, 1989, 1999, 42, 5sp, 89, adjust, clutch, f150, f250, ford, peadal, pickup, safety, saftey, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
