Unidentified plug
Unidentified plug
93 5.8 out of a F-150 into my 93 F-250
There is a plug that is in the same part of the loom that goes to the A/C compressor, there is green with an orange stripe wire, and a black with a yellow stripe wire. The plug is kind of roundish, black with kind of grey rectangle end where the wires go into the plug.
My repair manual doesn't show it and there is nothing on the engine that I see for it to plug into.
Any ideas what it goes to?
I'm with ya, I've got two plugs on the right side (facing the engine) by where a compressor or something should be. I haven't really researched it yet but this got me thinking about it. I don't know the colors of my two offhand, but one is round and the other is somewhat rectangular-shaped.
Not to go off topic, but if a truck (96 351W) didn't come with air, would the plug for the compressor still be there dangling? I wonder what the other plug is for...
Are you sure that engine wasn't out of a '94? In the shop manuals wiring diagrams, the '94 was the first year to include a High Pressure cut off switch in the outlet line from the compressor. This might have something to do with the change to the R134 Freon in '94. Your wires match the diagram.
The switch addition was the only change to the wiring, so you could simply cut the plug off and join the wires together to make your AC work.
When I added AC to my '88, I used everything for a '94, so the switch was included.
mrjimbov
03-19-2016 08:49 PM
Linusthedog
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
05-20-2015 10:40 AM
fordka
10-12-2014 05:24 PM
NY Signman
10-03-2014 10:46 PM
