You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I got ahold of about 100 gallons of oil that is titrating very high and when i try and do the transesterification it just turns into glop. I have read a little about putting sulfuric acid into the oil with methanol and mixing it to lower the titration numbers. Anyone using this method?
That really isnt that bad. How much methanol are you using. You could also put glycerin in it, Heat and let settle. It will pull water and reduce your titration number a little. If you are making glop it may be because of water.
That's what I do when I get nasty oil. It adds another day to the process, but results in lower titration due to a partial reaction taking place. The glyerol that settles out is much thicker, and the oil clearer after the process. I use KOH however.
Could also try and find a different source of oil and mix the two together to get lower titration. Have done this too...
__________________ Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!! 2002 TDI New Beetle - also likes Bio.
On the few occasions I've gotten "nasty" oil I just add a little of it to my normal "good" oil and process away! I also use KOH and find it a lot better than NAOH.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
Don't like Sulfuric Acid myself, nasty stuff. Ruined too many pairs of jeans, a car seat, got in trouble with the wife...
I got it from a local conveinence store and i dont know what type of oil it is so i guess im a little lost. Im making 1 liter batches just to test with and they have all come out as glop using this method
1L oil
200ml methanol
+5 whatever i titrate NAOH
I have also heated each batch to about 300F on my stove to get the water out. Any other suggestions on getting water out? The oil looks milky before i heat it and then after its heated and cooled you can see thru it. Any suggestions appreciated.
Could be several thing i guess. One is it could be a synthetic veg oil. It also sounds like it may be partally hydronated oil to. There is a place were i get there oil and they use a creamy butter type stuff. I mix it in with my other oil. Also you could try KoH. It is more tolerant of high titrating oil and titration mistakes.
i read somewhere that filtering to 10 or less microns will remove some of the water out of the oil. Have you seen this to be true or am i wasting my time filtering the oil that small?
I dont know about removing water unless it was a water trap type of filter, But filtering down to 10 or less microns wont hurt. It will give a better reaction.
Filtering doesn't remove water, but it does help with titration due to removing the bigger chunks. I don't filter that small going into the processor though, through screen first then a paint strainer (100 micron?) See my gallery. Filter into 55 gallon plastic drum, with output into reactor at the 20 gallon level. Crap that makes it through the filter settles to the bottom of the barrel and is drained off. With Turner and Fab on using KOH.
