Lock Actuator Fix WITH Pictures! - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 08-20-2010, 09:48 AM
rustydailey rustydailey is offline
rustydailey is starting off with a positive reputation.
I did mine yesterday. I also fixed a broken window switch. I was pretty happy because I didn't get burned with the soldering iron.
  #47
Old 08-22-2010, 10:07 PM
Bobbys Big Red Rig's Avatar
Bobbys Big Red Rig Bobbys Big Red Rig is offline
Bobbys Big Red Rig is gaining momentum as a positive member of FTE.
Well I did not do so well, missed the picture with the screw driver and tab, read it just didn't see the picture. Should of had my glasses on when reading instructions. Broke part of the channell on the accuator 3 out of four times. Was enough left to put them in place and hold for now. Does the tab prevent accuator from going on easy, I had a hard time reinstalling. The resister was the easy part all went well with motor.
  #48
Old 08-23-2010, 10:04 PM
JonathanN's Avatar
JonathanN JonathanN is offline
JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.
No, it shouldn't... it just holds it in there. Hopefully, you actuator won't push itself out. Time will tell... if it stays in there, don't worry about it.
  #49
Old 08-31-2010, 09:18 PM
hiredgun18's Avatar
hiredgun18 hiredgun18 is offline
hiredgun18 is starting off with a positive reputation.
Did my drivers side today,broke the plastic piece that holds the actuator in the truck. I got it on,but i guess we'll see if she stays! Drivers side lock works good though! I did the tinfoil..
  #50
Old 09-04-2010, 02:27 PM
X JBM X's Avatar
X JBM X X JBM X is offline
X JBM X is starting off with a positive reputation.
Bump. Another satisfied customer. It took me about 2 hours to get everything back together and working (cutting a piece of metal, or grinding in my case, to the right size took the longest) but the door lock works great! Thrilled that I don't have to jump across the truck to open the door.
  #51
Old 09-14-2010, 07:19 PM
USAF CCM's Avatar
USAF CCM USAF CCM is offline
USAF CCM has a good reputation on FTE.USAF CCM has a good reputation on FTE.
Jon,
A big thanks for the pictures & writeup. My passenger door automatic locks suddenly stopped functioning. I thought about the superb fix you and another have discovered, but in the end after learning I could get the "new & improved" actuators from Ed for approximately $37.00 each, I decided to install the newer actuators.
I made minor procedural changes to the R & R: I popped out the wire harness tab attached to the actuator (not it's own plug) since I had more leverage. I also had to remove a small plastic corner piece on the bottom inside righthand of the door which allowed me to move a gray cloth/plastic inner door cover out of the way.
Your mention of taping the outside of the door around the handle SAVED my paint job.....this is a must do. Thanks again & reps sent. The lock works again!
  #52
Old 09-14-2010, 08:04 PM
Majikdog's Avatar
Majikdog Majikdog is offline
Majikdog is starting off with a positive reputation.
Worked like a charm!
Just did this procedure with all the locks(4) using a piece of 1/2" copper tubing( left over scrap from jobs) folded in half and hammered flat. Cut to same size has piece that was in there. I didn't drill anything out. Just pryed it open on all sides except where the rivets are still attached. Left it in hanging in door and got the piece out. Used a tie strap to close it back up. I'm so happy I can use my locks again.
Anyone have or know of why my ignition key won't work in door lock to open or lock at door? Just curios why that is?
  #53
Old 09-14-2010, 10:26 PM
hiredgun18's Avatar
Quote:
I have this SAME problem,i have to turn the key several times now to get the door to unlock on drivers side,anyone know why?
  #54
Old 09-14-2010, 10:31 PM
JonathanN's Avatar
You wore it out after you wore the door locks out, maybe?
Actually, to the guy before, has it always been like that, or has it just be getting worse as time goes on? If it's always been like that, then I'd imagine that it might be different than the ignition key. If the cylinder was ever replaced, they may be keyed differently. I chose to key my cylinder so I wouldn't have that problem... who wants two keys anyways?
  #55
Old 09-14-2010, 10:43 PM
hiredgun18's Avatar
No,the door always unlocked on the first turn till i did this fix.
  #56
Old 09-14-2010, 10:47 PM
JonathanN's Avatar
Hmmm... must've knocked a rod loose, or didn't snap a clip all the way. Did you look in there to see?
  #57
Old 09-14-2010, 10:54 PM
hiredgun18's Avatar
I did,but i didnt see anything outta wack?
  #58
Old 09-14-2010, 10:57 PM
JonathanN's Avatar
Weird... all I can say is check your rods and them funky clips that hold the rods into the end of the levers they attach to.
  #59
Old 09-14-2010, 11:02 PM
hiredgun18's Avatar
Yeah,obviously something is amiss,process of elimination now..
  #60
Old 09-14-2010, 11:15 PM
mechelement's Avatar
mechelement mechelement is offline
mechelement has a good reputation on FTE.mechelement has a good reputation on FTE.mechelement has a good reputation on FTE.
Great thread. Is it possible to find another solid metal resistor to replace the worn out one?
What about these: VISHAY DALE|WSL2512R1000FEA|RESISTOR, METAL STRIP, 0.1 OHM | Farnell United Kingdom
Strange "stain" around sunroof shingles 1997-2006 Expedition & Navigator 10 07-04-2016 03:02 PM
Custom Hood, One Of A Kind. WARNING PIC. HEAVY! OGTerror Appearance & Dress-Up 9 05-30-2011 01:23 PM
F350 6.2L Towing 10k Lbs Video fordmdb 1999 to 2016 Super Duty 26 08-23-2010 11:32 PM
List Of Damaged Parts On Current Vehicle OGTerror Offroad & 4x4 10 01-14-2010 07:00 AM
May all Rize. OGTerror Offroad & 4x4 17 10-01-2009 12:23 AM
Tags
1999, 2002, actuator, actuators, check, f150, f250, fix, ford, good, lock, pics, switch, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
