Lock Actuator Fix WITH Pictures! - Page 3 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #31
Old 08-06-2010, 01:44 PM
bones68 bones68 is offline
bones68 is starting off with a positive reputation.
How do you get that little tab off that holds the actuator? I don't want to break that tab.. Do you have to remove the torx screws that hold the latch mechanism before you can get the actuator out?
  #32
Old 08-06-2010, 05:44 PM
JonathanN's Avatar
JonathanN JonathanN is offline
JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.JonathanN has a great reputation on FTE.
Nope... but on your first lock, if you can't find the tab that you have to pry with a screw driver, then you could take the whole assy. out and then you'll know what to look for when you do the next one. But look REALLY close at the picture and look where the screw driver is stuck. if you can't see it, let me know and I'll post an enlarged picture.
  #33
Old 08-06-2010, 05:57 PM
rbaker6336's Avatar
rbaker6336 rbaker6336 is offline
rbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to behold
There was one tab on the front door actuator I couldn't get loose.I pulled the whole thing out the outside handle hole to get to it
  #34
Old 08-06-2010, 11:50 PM
Thanks Guys.. Jonathan if you could enlarge the picture that would help.
To remove the whole assembly do I just remove the 3 torx screws on the door edge?
  #35
Old 08-17-2010, 12:51 PM
h1ncxtls h1ncxtls is offline
h1ncxtls is starting off with a positive reputation.
Now locks work....but batteries runs down :(
Super job on the actuator post.....
I "fixed" all 4 of my 2002 F250 actuators and left the garage a happy man....about 3 days later my wife went to take the truck out and it barley had enough power in the batteries to crank over. What would cause the "fixed" lock actuators to drain my batteries? I pulled the main fuse for the locks and the truck is starting fine....after a re-charge.
Any clues would be appreciated.
  #36
Old 08-17-2010, 12:58 PM
JonathanN's Avatar
That, or you were just "lock happy" and drained the batteries watching the locks work because it'd been so long since you used them. HAHA!!! Hmmm... I have no idea. My locks never did that... did you just make metal dummies to put in the ends or did you do the foil thing?
  #37
Old 08-17-2010, 01:01 PM
metal dummies
I did the metal dummies....was so easy....once I did one.....I called my Dad and "fixed" his Ranger door lock actuators. His battery is fine....must be my personal rain cloud. I hate electrical problems....hard to track down.
Any help much appreciated!
  #38
Old 08-17-2010, 01:04 PM
JonathanN's Avatar
Check your switches... might be stuck. If you haven't used/actuate the locks since they went dead, I'm wondering if something is getting hung up? I don't know... any ideas, fellas?
  #39
Old 08-17-2010, 01:08 PM
megawatt00's Avatar
megawatt00 megawatt00 is offline
megawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputation
You may be grounding one of them out ever so slightly and it is acting as a resistor ( why the fuse does not blow)and draining the battery.
  #40
Old 08-17-2010, 01:16 PM
30 amp Maxi Fuse
The fuse is one of the 30 amp Maxi fuses.....it would take a good ground to "pop" it.
I may pull the power plug to the back door locks and see if the battery drains...try to single out which door is the culprit then tear into it. I'm just not that savey on electrical problems....ie testing switches and motors etc....
  #41
Old 08-17-2010, 02:06 PM
bkgeig bkgeig is offline
bkgeig is gaining momentum as a positive member of FTE.bkgeig is gaining momentum as a positive member of FTE.
On my third door I couldn't get all the plastic pieces inside the actuator to seat properly and the actuator wouldn't work. I ended up drilling out the two metal rivets to completely open the actuator. On the fourth door I might just drill them out to start with, in order to have complete access to the actuator, and then replace them with small screws. I hope I don't have to do that fourth door for a while.
I don't see how the resistor could be draining your battery. The resistor simply sits between the switch on the door and the electrical motor in the actuator. Something would have to be supplying constant current to the resistor, and if this happened, I would expect to see one or more of the doors continuously locked or unlocked, depending on the current flow, or the motor would burn out and not work at all. I suspect the current drain you're seeing is coincident with the upgrade you made, not dependent on it. The first place to start is to check whether your battery is indeed seeing a drain with the engine off. There are good directions on this site for checking for battery drain, I've had to use them myself.
  #42
Old 08-17-2010, 05:52 PM
hiredgun18's Avatar
hiredgun18 hiredgun18 is offline
hiredgun18 is starting off with a positive reputation.
Hows does the tinfoil work??
  #43
Old 08-17-2010, 08:41 PM
JonathanN's Avatar
It's when you wrap the resistor in foil instead of making a dummy. I tried the foil, but the whole thing kept tearing on me when i tried to put it in. Also, on another friend's actuator, I was actually able to bend the contacts that held the resistor to the point where they shorted and I didn't even have to put a dummy in the cap. You could try that, it just takes a bit of patience.
  #44
Old 08-19-2010, 12:16 PM
Bad 3 yr old AutoZone Battery
Gang,
It wasn't the lock acutators after all.....I tested my 3 year old Duralast batteries and the driver side battery dropped to 6 volts when I tried starting the truck.....bad battery!! So for a bit I have been running off of one battery.
I replaced the old batteries with new Interstate batteries.....put the fuse back in for the locks and I'm once again enjoying my power locks
Thanks for all of your tips and clues.
  #45
Old 08-19-2010, 12:22 PM
JonathanN's Avatar
Awesome! It's awesome to enjoy the locks after all those years, isn't it!?
Glow Plug Swap with Pictures!!! JonathanN 1999 - 2003 7.3L Power Stroke Diesel 42 10-23-2014 09:31 PM
Cold A/C Mod/Ranger Valve Mod WITH Pictures! JonathanN 1999 to 2016 Super Duty 36 08-19-2014 04:55 AM
Ed's Decals... Check 'em Out! JonathanN 1999 - 2003 7.3L Power Stroke Diesel 32 12-10-2012 11:59 AM
HPOP O-ring Repair WITH Pictures! JonathanN 1999 - 2003 7.3L Power Stroke Diesel 7 12-05-2012 04:37 PM
My HPx WITH Pictures! JonathanN 1999 - 2003 7.3L Power Stroke Diesel 43 10-01-2010 08:50 PM
Tags
1999, 2002, actuator, actuators, check, f150, f250, fix, ford, good, lock, pics, switch, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
