Lock Actuator Fix WITH Pictures!
#137
#138
Although the square from the original picture looks like a flat piece of metal, it is actually a thermistor or thermal resistor. They work by varying resistance internally according to temperature. So lets say the door lock switch is pressed and held down...the motor starts to heat up...the thermal resistor increases its internal resistance due to the heat and wah lah() it is too much resistance to complete the electrical path and therefore will not let the door lock actuator function properly. By swapping this out for a solid piece of metal or tin foil, you are creating a short across the contacts or a zero resistance condition. Hope this helps.
#139
#142
No pics x2
Bringing up an old post to ask a question.
Will this work for the replacement for my 2000 EX rear hatch lift gate?
2000-2005 Ford Excursion Tailgate Lock Actuator Motor - Dorman 746-148 - - PartsGeek.com
#145
I've got a sluggish lock problem on 2 of 4 doors on my 2001 F250. It sounds like the resistor may be the first place to start with the repair.
I can't see any of the pics on this post. Is it b/c of my membership level or are they just not hosted anymore.
Thanks for any help you can provide.
JC
JC
#147
Thanks for the pictures and especially the little slit trick. It only took a couple of minutes to get my bad actuator out once the door panel was off. I also did not take the door handle off, just the inside door panel. The slit trick was the ticket! I pulled the actuator apart but decided to try out the new units from ebay. They look like a redesigned unit from what I have now. If they do work out, you can't beat $40 shipped for all four doors!
4 Ford Door Lock Actuators 2 Left 2 Right New | eBay
#149
