Lock Actuator Fix WITH Pictures! - Page 10 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #136
Old 05-28-2013, 02:07 PM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
Originally Posted by F-250 Brock View Post
Why not?
Quote:
Originally Posted by Chipworkz View Post
Why not what?
x2.
Why not, what?
Stewart
  #137
Old 05-28-2013, 02:39 PM
Smokiesman's Avatar
Smokiesman Smokiesman is offline
Smokiesman has a very good reputation on FTE.Smokiesman has a very good reputation on FTE.Smokiesman has a very good reputation on FTE.Smokiesman has a very good reputation on FTE.
This is a great post on fixing your PDL ! I have read every post but maybe someone can explain how this resister being a solid piece of metal wears out or why it wears out ??
Smokie
  #138
Old 07-06-2013, 10:14 PM
slwsmkn444 slwsmkn444 is offline
slwsmkn444 is starting off with a positive reputation.
Quote:
Smokie
Although the square from the original picture looks like a flat piece of metal, it is actually a thermistor or thermal resistor. They work by varying resistance internally according to temperature. So lets say the door lock switch is pressed and held down...the motor starts to heat up...the thermal resistor increases its internal resistance due to the heat and wah lah() it is too much resistance to complete the electrical path and therefore will not let the door lock actuator function properly. By swapping this out for a solid piece of metal or tin foil, you are creating a short across the contacts or a zero resistance condition. Hope this helps.
  #139
Old 07-08-2013, 07:36 AM
microdevil45's Avatar
microdevil45 microdevil45 is offline
microdevil45 is gaining momentum as a positive member of FTE.
Quote:
Also I must add that while this fix does work. IF for some reason you have a surge or some other electrical function that goes to these motors it will FRY them. Ask me how I know. I was upgrading my leds and one of the soldiered tabs was a frogs hair too long and shorted out on the button function side and bam. All three of my Fixed door lock actuators are fried and won't even pull up and stay up. My fourth the one that was original that wasn't fixed is still able to be moved by hand (just not electrically). So be careful when doing this.
  #140
Old 08-06-2013, 06:34 PM
Greeen-TR6 Greeen-TR6 is offline
Greeen-TR6 is starting off with a positive reputation.
Does anybody know if this will work on a 2000 Expedition? It looks like the lock actuators are different.
  #141
Old 08-15-2013, 08:08 AM
brooksa44's Avatar
brooksa44 brooksa44 is offline
brooksa44 is starting off with a positive reputation.
What happened to the pics?
  #142
Old 09-14-2013, 02:56 PM
Joshua Sirchuk's Avatar
Joshua Sirchuk Joshua Sirchuk is offline
Joshua Sirchuk is gaining momentum as a positive member of FTE.
No pics x2
Bringing up an old post to ask a question.
Will this work for the replacement for my 2000 EX rear hatch lift gate?
2000-2005 Ford Excursion Tailgate Lock Actuator Motor - Dorman 746-148 - - PartsGeek.com
  #143
Old 09-14-2013, 08:26 PM
Pitcrw6's Avatar
Pitcrw6 Pitcrw6 is offline
Pitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant future
Yeah, what happened to the pics?
  #145
Old 10-22-2013, 05:53 PM
ks4wheeler's Avatar
ks4wheeler ks4wheeler is offline
ks4wheeler is starting off with a positive reputation.
I've got a sluggish lock problem on 2 of 4 doors on my 2001 F250. It sounds like the resistor may be the first place to start with the repair.
I can't see any of the pics on this post. Is it b/c of my membership level or are they just not hosted anymore.
Thanks for any help you can provide.
JC
  #146
Old 12-20-2013, 11:38 PM
LuisJ LuisJ is offline
LuisJ is starting off with a positive reputation.
very good videos.... thanks to the guys taking the time to make them and making things a lot easier for the rest of us.
  #147
Old 02-17-2014, 09:19 AM
pennsylvaniabo pennsylvaniabo is offline
pennsylvaniabo is starting off with a positive reputation.
Thanks for the pictures and especially the little slit trick. It only took a couple of minutes to get my bad actuator out once the door panel was off. I also did not take the door handle off, just the inside door panel. The slit trick was the ticket! I pulled the actuator apart but decided to try out the new units from ebay. They look like a redesigned unit from what I have now. If they do work out, you can't beat $40 shipped for all four doors!
4 Ford Door Lock Actuators 2 Left 2 Right New | eBay
These still holding up for you? That is a pretty good price if they last.
  #148
Old 09-01-2014, 01:34 AM
chad11 chad11 is offline
chad11 is starting off with a positive reputation.
Why aren't the pictures showing?
  #149
Old 09-01-2014, 01:47 AM
Pitcrw6's Avatar
Probably bc the orginials were on photobook and the person moved the file so they don't show up anymore. Try the tech folder at the beginning of the thread or the tech folder in the excursion forum. Stewart might have added it there also.
  #150
Old 09-05-2016, 09:22 PM
CharlyG's Avatar
CharlyG CharlyG is online now
Just Passin Thru
CharlyG is a name known to allCharlyG is a name known to allCharlyG is a name known to allCharlyG is a name known to allCharlyG is a name known to allCharlyG is a name known to all
Pictures are gone...
Glow Plug Swap with Pictures!!! JonathanN 1999 - 2003 7.3L Power Stroke Diesel 42 10-23-2014 09:31 PM
Cold A/C Mod/Ranger Valve Mod WITH Pictures! JonathanN 1999 to 2016 Super Duty 36 08-19-2014 04:55 AM
Ed's Decals... Check 'em Out! JonathanN 1999 - 2003 7.3L Power Stroke Diesel 32 12-10-2012 11:59 AM
HPOP O-ring Repair WITH Pictures! JonathanN 1999 - 2003 7.3L Power Stroke Diesel 7 12-05-2012 04:37 PM
My HPx WITH Pictures! JonathanN 1999 - 2003 7.3L Power Stroke Diesel 43 10-01-2010 08:50 PM
Tags
1999, 2002, actuator, actuators, check, f150, f250, fix, ford, good, lock, pics, switch, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
