Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > New England Region > Massachusetts Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Massachusetts Chapter Join Chapter, Leader: donjamer
  #1 (permalink)
Old 05-02-2010, 08:20 PM
MadFrank81's Avatar
MadFrank81 MadFrank81 is offline
Garage is empty, add now
MadFrank81 is starting off with a positive reputation.
Pass inspection?
Hey guys, I was wondering if any of you have any insight into exactly what will and won't pass the MA safety inspection when it comes to rust?
I recently got my '77 F250 running and am working on the tires right now, after that I'm just gonna do a good tune up, change all the fluids and it'll be time to see what it'll need to pass. I do have holes in the floor behind the seat so I know that'll have to be done but the entire cab is pretty rusty. Frame is fine. Anyone know any inspection shops with "bad vision"?
__________________
1977 F250, 4x4, 351m, NP205, NP435, Converted Dually, Holmes 220 Sling Wrecker
1977 W300, Factory Dually, 318, NP203, 4 spd, Sling Wrecker
2009 Ranger XLT 2.3 Auto Ext. Cab
2008 Taurus SEL 3.5 AWD Auto
2003 Rio 1.6 Auto
  #2 (permalink)
Old 05-03-2010, 12:21 PM
c4barnes c4barnes is offline
c4barnes is gaining momentum as a positive member of FTE.c4barnes is gaining momentum as a positive member of FTE.
Pretty much any hole into the passenger compartment gets flagged, although I've never seen anyone actually crawl under the truck. Not sure about the rust over the wheel wells - I'll find that out tonight, actually.
__________________
Member Massachusetts Chapter
'73 F100 2wd, '91 302 roller, NP435
'86 F350 CC 4wd, C6, 6.9, Banks Turbo
  #3 (permalink)
Old 05-03-2010, 12:43 PM
rocdril's Avatar
rocdril rocdril is online now
rocdril has a great reputation on FTE.rocdril has a great reputation on FTE.rocdril has a great reputation on FTE.rocdril has a great reputation on FTE.
Back in the day, we would just put duct tape on the inside of the cab where the rust was, then spray the underside w/undercoating, to get through inspection. Just sayin.
__________________
One 7.3s, One 6.4, and Three 6.7s
2012 Raptor, way too fast.
Semper Fi
RAY
  #4 (permalink)
Old 05-04-2010, 10:49 PM
MadFrank81's Avatar
Thanks guys, inspection is still a long way off for the beast but the undercoating idea might actually work!
__________________
2003 Rio 1.6 Auto
  #5 (permalink)
Old 05-14-2010, 02:07 PM
donjamer's Avatar
donjamer donjamer is offline
2006 Ford F-350
donjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputation
Rot over the wheel wells is fine..
My son's 77 F250 failed due to rust in the cab corners.. He had some new sheet metal ones that we just painted then attached it to the truck with sheet metal screws..
Looks good from a distance and it was enough to pass..
Make sure all your lights work including the back up lights.. We had to fudge that one also..
__________________
Don #3 SlackMaster
Chapter Leader of the Massachusetts Chapter
Join the MA Chapter Here
Currently own:
2006 F350 Lariat CC Super Duty, 6.0 L Diesel
FTE Fraternity OF Blue Max
  #6 (permalink)
Old 05-14-2010, 02:14 PM
I can confirm that one - forgot to post. I have the rusty hips obligatory on all 80s trucks, but they didn't call it. I have no rust on the cab, so I didn't get to test that rule.
__________________
  #7 (permalink)
Old 05-16-2010, 07:42 AM
mattystowe's Avatar
mattystowe mattystowe is offline
mattystowe is starting off with a positive reputation.
i filled my wheel wells with great stuff, scraped of the high spots and painted it a bit. just taped carboard over the holes and stuck the tube behind the tape and in between carboard making sure to fill enough to make a large brick between inner and outers. also large voids in front lower fenders and a few lower rear spots rebuilt with same substance.. passed safety no probs 5 bucks or so. leave cardboard on for at least 3 days so it cures well and compact, makes it harder.
I need a new power brake booster to get rid of the hiss in the cab causing it to run lean.. wish i had a 95 sometimes, no emissions then. 1 frekin year
__________________
Matt Reid of Cape Cod
Tags
cab, corner, f250, floors, guidelines, inspection, mass, massachusetts, motor, pass, passing, rotted, rust, rusted, vehicle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
