I know this is a little backwards of the normal warning buzzer post, but I would like to know how to check why my door open, lights in, seat belt, and key in the ignition is not working.
insert the key turn to the on position there is a hole under your column right under the key stick a pic in the hole to release the tab and pull the cylinder out
