up pipe replacement options for OBS
I'm replacing my engine. Got the old one out, and the up pipes are too chewed up at the turbo ends to reuse -- they couldn't form a good seal, so I need to replace.
1. Does anyone know the Ford part numbers for the up pipes? I've looked at the ubiquitous Powerstroke part number list floating around, and it says Up Pipe-see Turbo Exhaust Collector below. But it never actually lists the part numbers.
2. Ford parts may not be available even if I have the part number. Does anyone know of a vendor or exhaust shop that sells an aftermarket version of these?
3. Are there any upgrades I should consider? International makes bellowed ones which eliminate the donut seals and leaks. These are sold by a number of folks with or without ceramic coating. But they only fit the larger inlet Super Duty turbochargers, not the ones we have.
Thanks for any help you can give.
Dan, there is a version of the bellowed up pipes for the OBS. The part number has been posted a few times but Masami or Old Man Dave on TDS or PSN. Powerstrokeshop.com used to have a kit with new pipes, donuts and such. You might want to look over there. I do not know of anyone making a aftermarket piece for the OBS charger. BDP has brass donuts that are supposed to work well.
Tom
Tom
Shoebear, I used the brass donuts from Beans but so far I don't have any encouraging news. They have to be torqued down after a cycle of warming up. Well, mine leak and I'll be darn if I know how to get to them to retorque them. I'm going to try soon by warming them up and droping a hot DP down and who knows from there?!
If anyone else has experience with the brass donuts, please chime in.
Here are Ford and International part numbers, courtesy of Patrick Feeley on another site.
Turbo Exhaust Collector Donut (at top of each manifold-to-turbo up-pipe)
(Ford) F4TZ-6K854-C
(NAPA) f17250 (Chevrolet application, but works for PSD)
Turbo Exhaust Up-Pipes
(Ford) F4TZ-6K854-A (Driver’s side), cross references to IH 1818165C2 but can't verify if it's correct
(Ford) F6TZ-6K854-A (Passenger side), cross references to IH 1824434C1 but can't verify if it's correct
(International, bellowed up-pipe kit for 94-97) 1843486C92
Turbo Up-Pipe Bolts
(International) 1821640C1 (long for manifold end, 4 required), part number was superseded by part number W300013
(International) 1822895C1 (short for turbo collector end, 4 required), try 1844044C1 which will cross to W301160 which was superseded by W301640
(Ford) 40066R1 (Nuts, 4 required), superseded by W300051
(Ford) F4TZ-6K854-C
Turbo Up-Pipe Bolts
However, I've asked my local IH dealer for a quote on that part along with a bunch of others. He'll fax me back when he has the list, and I'll post his quote when I get it.
