2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Off set tires.
Old 05-02-2010, 11:08 AM
recluse's Avatar
recluse
recluse is offline
Off set tires.
I have 3'' Ready Lift on my 2007 Expedition with 305/70R17 BF Goodrich tires.
The stock rims come with +44mm off set. I want to replace stock rims with a different off set.
I would like to go with 0mm off set, 2nd option would be +22mm. Like a man I think bigger is better.
Has anyone installed off set rims? I know some mods have to be done to the front plastic bumper to prevent rubbing.
Thnx.
Old 05-02-2010, 01:17 PM
Tylus's Avatar
Tylus
Tylus is online now
MMNC (SS)(Ret)
look at the 04-08 F-150 setups...and the 09+ setups
we have the exact same front suspension as them. Just be careful with going too far. You might rub the frame
Old 05-04-2010, 05:35 PM
recluse's Avatar
recluse
recluse is offline
I've found what I want
Pro Comp Series 7028 Cast-Blast Wheels - Xtreme Alloy Cast Wheels, Pro Comp Cast Wheels
The rims have 0 mm offset.
Can anyone advise how bad is splashing with the wheels sticking out by almost 2''?
