ECM location on a 93' F150
Old 05-02-2010, 09:07 AM
midnightmike's Avatar
midnightmike
midnightmike is offline
Is the ecm located behind D/S kick panel on an 93' , and how do you remove it ? Also what is the module located behind the glovebox ?
Old 05-02-2010, 10:00 AM
subford's Avatar
subford
subford is offline
Yes that is where it is at.
First you disconnect the battery ground cable.
Then you remove the inter fender to fender screws.
Next take a 10mm 1/4" drive socket and loosen the center bolt in the plug and remove the PCM plug.
Remove the two screws around the plug.
Pull the PCM out between the fender and the inter fender.
RABS module.
finlander42
11-27-2014 12:39 PM
JWGJR_H
11-04-2012 03:37 PM
renchr56
01-12-2011 12:44 PM
1ford1
1999 to 2016 Super Duty
07-20-2009 09:46 PM
cfhurdle
12-04-2004 09:02 AM
Quick Reply: ECM location on a 93' F150
