ECM location on a 93' F150 - Ford Truck Enthusiasts Forums
Old 05-02-2010, 10:07 AM
midnightmike midnightmike is offline
midnightmike is starting off with a positive reputation.
Is the ecm located behind D/S kick panel on an 93' , and how do you remove it ? Also what is the module located behind the glovebox ?
Old 05-02-2010, 11:00 AM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Quote:
Yes that is where it is at.
First you disconnect the battery ground cable.
Then you remove the inter fender to fender screws.
Next take a 10mm 1/4" drive socket and loosen the center bolt in the plug and remove the PCM plug.
Remove the two screws around the plug.
Pull the PCM out between the fender and the inter fender.
RABS module.
location of ecm on F250,(help!!) JWGJR_H 1987 - 1996 F150 & Larger F-Series Trucks 11 11-04-2012 04:37 PM
94 f150 injectors not firing, ECM location Motorheadblb 1987 - 1996 F150 & Larger F-Series Trucks 3 05-22-2011 10:55 PM
ECM or BCM? 1ford1 1999 to 2016 Super Duty 6 07-20-2009 10:46 PM
ecm location rondawgg1118 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 04-24-2009 08:49 PM
ECM location 94 E-150 TimLorentzen 1968-2013 Full Size Vans 3 03-29-2009 10:11 PM
Tags
150, 1996, 93, 95, ecm, f150, f450, ford, ground, located, location, pcm, remove, removing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
