turn signal does nothing. I thought it might be the flasher but the hazzard works fine. Lights all work fine withe the hazzards on. Checked fuse its fine. Dont know what else to check.
This thread has instructions on how to replace your turn signal switch. I suggest taking it apart as the directions state and test the switch and wiring.
Just make sure when you use the hand signals, you make sure all FOUR fingers are pointed the same direction. Use of one finger only means something entirely different.
Aren't there TWO different flashers in there? One for the hazards and one for the turn signals?
Try tilting your steering wheel up and down and wiggling the wiring harness that runs down the steering column. Sometimes it can get pulled too tight and loose contact.
