P0281 with smoke
Old 05-02-2010, 12:32 AM
Wiredoge4's Avatar
Wiredoge4
Wiredoge4 is offline
Exclamation P0281 with smoke
<TABLE border=0 cellSpacing=0 cellPadding=6 width="100%"><TBODY><TR><TD style="BORDER-BOTTOM: 1px inset; BORDER-LEFT: 1px inset; BORDER-TOP: 1px inset; BORDER-RIGHT: 1px inset" class=alt2>Originally Posted by Wiredoge4
Hey Chris,
I have a new issue after fixing the no start issue. Now I have a issue with smoke. The KOER cylinder Con test shows a code of P0281. Cylinder #7 circuit con balance fault. Is this caused by a o-ring. Also cylinder #7 is on the passenger far back or are they meaning firing order.Thanks for your help.
SemperFi
Cliff
</TD></TR></TBODY></TABLE>Yea, #7 is the far back one on the passenger side. The code just means that injector is not holding up it's end of the deal. O-rings are a possibility. Can you watch rotational velocity numbers and see how high #7 is?
Have you started a thread on this? I'll try and find it. <!-- / message --><!-- sig -->
__________________
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 325,000 & counting.
RHN Mods & Maintenance
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
Old 05-02-2010, 12:35 AM
Wiredoge4's Avatar
Wiredoge4
Today I replaced all O-rings on the passenger side. While I was there I also replaced the glow plugs. The trouble is still there. Now the truck has no power and still smokes. I will be doing some tests on the truck with the AI. Any ideas.
Old 05-02-2010, 04:31 PM
Wiredoge4's Avatar
Wiredoge4
KOEO Tested ok Also the buzz test was ok. I'm waiting to do the rest in a few.
Old 05-11-2010, 01:33 PM
Wiredoge4's Avatar
Wiredoge4
I found that I broke the MAP senor. I guess when I took the Valve cover off I must of jammed the hose that comes from the turbo to the map sensor off. I have some red neck glue (JB Weld) on it for now. Waiting for that to cure. If that doesnt work then Clay has one on its way to my house. This might be where the power went. Sounds like the turbo is not spooling.
Also the smoke is still there and the P0281. Should I just have this one rebuilt or buy a new one.
Old 05-12-2010, 06:17 AM
F350-6's Avatar
F350-6
F350-6 is offline
Sounds like #7 is bad. The only other test I know of would be to remove the valve cover and start the engine. Watch the oil discharge from that injector compared to the others.
Several run rebuilt injectors with no issues, some have had issues. I wouldn't get one from Ford. If you want new, search Alliant power and find a dealer near you. If you want rebuilt, talk to Clay. Don't order a rebuilt from Pensacola diesel, no matter how good their prices seem.
Old 05-13-2010, 06:37 PM
Wiredoge4's Avatar
Wiredoge4
I have sent my #7 injector to Clay. When I get the new one back I will let you know if this fixed the issue.
Old 05-13-2010, 06:42 PM
Wiredoge4's Avatar
Wiredoge4
Chris
#7 is at 10%, #3 is at 0.7%, #5 is at 0.7%. I have replaced all o-rings on that side of the motor. I think its a bad #7 injector. What do you think. There is a post Dated May 2.
This was a late message I had sent to Chris. So dont get confused with it.
Old 05-13-2010, 07:10 PM
Riffraff Diesel's Avatar
Riffraff Diesel
Riffraff Diesel is online now
PREMIUM SPONSOR
Don't forget that I am an Alliant Dealer as well
Old 06-04-2010, 01:20 AM
Wiredoge4's Avatar
Wiredoge4
P281
I replaced Injector #7 and it now smokes more than it ever did. Also still pulls a p281 during con test. Buz test pass, KOER test passes.Rotational velocity still 10%. Does anyone think its rings. Smells like burning oil, but that could be the grease I put on the injedtor #7 when I put it in.
Old 06-04-2010, 07:51 AM
F350-6's Avatar
F350-6
F350-6 is offline
How many miles since you stuck the new injector in? It takes 50 - 100 miles to work the air out, and it will smoke a bunch when you first fire it up after an injector swap.
Sorry, forgot about that.
Old 06-04-2010, 09:16 AM
Wiredoge4's Avatar
Wiredoge4
I just let it warm up a little and drove it about 2 miles. I thought I was going to get pulled over it smoked so much.
Old 06-05-2010, 12:56 AM
Wiredoge4's Avatar
Wiredoge4
smoke Post P281
I did drive it around and the smoke is like it was before I replaced the injector. I did find a major oil leak at the turbo and a exhaust leak. The oil is hard to pin point where. Its hard to see around that area even with a mirror. But the oil leak is major.Is there a oil line for the turbo. Also the exhaust leak is at the exhaust side. Also oil is coming out the tail pipe. Should I pull the turbo?
Old 06-21-2010, 11:06 PM
Wiredoge4's Avatar
Wiredoge4
P281 smoke
I did find the oil leak. It was the exhuast back presure. Replaced that now oil leak is gone. Still have blue smoke. Bought a temp gun and found that the drivers side at idle all holes are about 280 all cylinders, but passanger side front #1 was 195, #3 cylinder was 148, #5 was 134 and #7 was 125. What do I need to look at next.
Old 06-22-2010, 05:07 AM
F350-6's Avatar
F350-6
F350-6 is offline
What does the contribution test show now? Was the #7 injector new or rebuilt?
Old 06-22-2010, 09:31 AM
Wiredoge4's Avatar
Wiredoge4
P281 smoke
Got it from clay. I think its a reman and cylinder con test fails the same with cylinder #7 circuit fault p-281.
Quick Reply: P0281 with smoke
