How to identify an F250 HD
Simular to how they decided if a truck got the dana 44HD or the dana 50. No one really knows.
Thanks guys,
I have the diesel engine, and full floater 10.25 rear end, so I guess that makes it HD (whether or not that an official designation).
I also found some good info on this topic at this thread...
https://www.ford-trucks.com/forums/2...1989-f250.html
Light duty or heavy duty did not depict what rear axle it got. I think that had to do with wheel base, engine, transmission, and GVWR all combined in some elaborate formula to decide what axle a truck got. I'v seen lots of LD F250's with FF, only 1 with Simi-float, and HD F250's with only FF's
I see on the other thread I linked a guy says if your GVWR is 8600 lbs you have an HD, anything less is LD.
Look at the GVWR on the sticker in the driver side door jam. It should match up with one of the rating above. It may also say HEAVY DUTY on the F250 badge on the fender, but im not sure what decided whether or not it got that badge.
Thanks guys,
I think super cab LD F250's got the Dana 50 while reg cab LD F250's got the dana 44HD. But im not positive.
