Smog Pump Chirp
Smog Pump Chirp
My smog pump chirps like crazy. I replaced it and after the break in period the new one stopped chirping. However, a couple thousand miles later it started chirping again so I replaced it a second time. Now the new one (even after the 500 mile break in period) wont stop chirping. Any suggestions? Will a little WD-40 damage the pump or CAT?
When the truck is running, it appears the pulley might be warped or the pump may not be properly aligned with the drive system. I didnt see a way to adjust it though.
Help please.
-Jon
'91 F-150 2WD 302
Help please.
-Jon
'91 F-150 2WD 302
Smog Pump Chirp
I don't beleive that your supposed to lubricate anything on the smog pump. When I replaced mine the reman company specifically stated in the directions that lubrication of the pump would void their warranty. If it's an old pump that your trying to milk along then I'd say anything is worth a try tho. You might getting some belt dressing and spray on the belt. This might help eliminate the possibility that the squeak is coming from the belt and the potential mis-alignment problem that you are seeing.
Randy
Randy
Fordication
11-17-2016 12:13 PM
nascar_20
04-22-2012 08:30 PM
Junebug_
1997-2006 Expedition & Navigator
01-14-2010 06:14 AM
