49 5 Speed Overdrive - Ford Truck Enthusiasts Forums
Old 05-01-2010, 02:09 PM
C-700 C-700 is offline
C-700 is starting off with a positive reputation.
Anyone interested in a good one. Figured I would ask before I shop it around. Should fit F3, F4, F5, F6, F7, & F8 for a lot of different years.
<!-- / message -->
<!-- controls -->
Old 05-01-2010, 02:18 PM
fifty-two_f1's Avatar
fifty-two_f1 fifty-two_f1 is online now
fifty-two_f1 is starting off with a positive reputation.
Can you post a picture and where are you located? Is it syncro?
Old 05-01-2010, 04:33 PM
bobj49f2's Avatar
bobj49f2 bobj49f2 is online now
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
As far as I know Ford didn't have a five speed in '48-52, just the three and four speeds.
Old 05-01-2010, 11:36 PM
If interested PM me. Ford did have a 5sp in 49 and I can open it up and get pictures.
Old 05-02-2010, 12:06 AM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
Lincoln 337cid
Old 05-02-2010, 10:09 AM
bobj49f2's Avatar
I apologize, I wasn't thinking about the larger F-7 and F-8 trucks.
If it's for the F-7 and F-8 with the 337 I would doubt it would fit the smaller flathead and if it did it would be a low geared heavy beast. From the drawings it looks like they have different mounting surfaces. I'm sure it would take a lot of modifications to make it fit the frame without any benefit but I could be wrong.
Old 05-02-2010, 10:11 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
That's a big, big tranny...
Great minds... eh, Bob?
Old 05-02-2010, 10:16 AM
bobj49f2's Avatar
Ross, I beat you to it!!
Old 05-02-2010, 10:23 AM
havi's Avatar
Thanks for the diagrams.
Old 05-02-2010, 10:34 AM
ALBUQ F-1's Avatar
postin' fool
Nope, at least not identical. In 53 they came out with a new model.
Old 05-02-2010, 11:56 AM
Will this five speed fit a 54 f600 with a 239 yblock? are the bell housings the same?
Old 05-02-2010, 03:50 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Quote:
No: F1-F6 used the same trans/ bell housing, etc. They used different stanchions under the transmission to adjust for the larger frames, but the main parts are the same.
F7 and F8 used the bigger flat V8 (337 cid) and the 5 spd trans.
The 5OD was standard on the F7 and optional on the F8.
The plain 5 spd was std on the F8 and optional on the F7.
IF I remember what the shop manual and operator's manual says.
Old 05-02-2010, 04:44 PM
ALBUQ F-1's Avatar
postin' fool
But if he used the bell from his F-600 Y-block, would the 5OD bolt up to that, and be the right length to flywheel?
BTW, the upper of Bob's pictures is the 5OD, and I don't see any synchros...?
Old 05-02-2010, 08:30 PM
I dont know if you guys are familiar with the 60s internationals, but they used 3 and 4 speed trans that should bolt right up to a ford. I have a 63 c1300 with a straight 6 and it has 4.88s and is SLOW. It has a three speed and a five speed with overdrive would be sweet for that truck. and if it did not bolt up as planned then it should go in my 54.
Oh shoot, I don't know - I didn't see he was talking about a '54 and Y block - must have only seen his user name. Talking before thinking again - sorry.
Went drag racing again today. pintoplumber 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 09-15-2016 12:59 PM
First build / 74 250 2wd dthut 1973 - 1979 F-100 & Larger F-Series Trucks 8 05-16-2016 09:28 PM
A little ID help would be great kylebegger 1957 - 1960 F100 & Larger F-Series Trucks 11 05-02-2015 09:07 AM
Prodigy P2 Brake Controller rdalley All Other Items for Sale 0 02-14-2012 01:16 PM
PCV Elbow enriched&beyound Modular V8 (4.6L, 5.4L) 0 03-10-2011 07:00 AM
Tags
1949, 1956, 5speed, antique, direct, drive, f8, ford, overdrive, pictures, speed, tractor, truck, trucks, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
